3.73+4000Stall
Old May 12, 2006 | 05:01 PM
mshadow's Avatar
Default 3.73+4000Stall
set shift points to 5800 and mph still hits limiter 1-2 2-3 how low should i go limiter is 6300
Old May 12, 2006 | 05:07 PM
foff667's Avatar
LS1TECH Sponsor
i usually use mph as the marker on the 1-2 shift at a minimum....but make sure your mph markers for both are setup properly otherwise you'll be chasing your tail.
Old May 12, 2006 | 11:01 PM
oztrack's Avatar
Go very low and work your way up. Mine was set at 5400rpm and still changing late.
Old May 13, 2006 | 09:29 AM
mshadow's Avatar
im gonna try 5400 for 1-2 and 5300 for 3-4
I searched the database of hptuner files...I can't belive no one else has a stock internals 4000-4400stall + 3.73 tune on there....
Anyone else have an examples of what they have used?
Old May 13, 2006 | 07:56 PM
oztrack's Avatar
What i did was set it so that my partial throttle tables controlled the shifts. This is proving more consistent than letting it use the WOT shift table.
My car is being told with 3.73s to change at 113kph and that is making it shift when warm at a steady 6400rpm.
To make it only use the partial shift tables - you set it so that it has to go over 100% to start the WOT tables (which is cant do) - then you dont have to satisfy 2 criteria speed and rpm. Just the speed in the partial shift tables at WOT
Old May 15, 2006 | 09:29 AM
wickedwarlock's Avatar
I have similar problem, stall is 2800 and gears are 3.93. It's gonna be a trial and error.
Old May 15, 2006 | 10:08 AM
SSpdDmon's Avatar
So you set {D1206} WOT Shift Mode Upper Threshold to 100.00 and this makes the PCM use the part throttle tables only?
Old May 15, 2006 | 11:16 AM
JZ'sTA's Avatar
I would increase the rev limiter to about 6700 until you get it figured out.
Reving to 6700 should be 100% okay, and will give you enough room to make changes.
Old Jun 18, 2007 | 06:16 AM
oztrack's Avatar
Yes thats right and it makes it very consistent.
