Stupid LC-1 acting up again!
Old May 16, 2006 | 09:22 PM
99whitews6's Avatar
Default Stupid LC-1 acting up again!
Went through just about every troubleshooting idea before replacing the Serial EIO with MPVI and then the WB worked fine. Four weeks later. I start up the car and check the WB output and it reads a fluctuating 20.45-20.65
Any ideas on where to start? I am going to check the output using Logworks tomorrow and see if it shows something else. Hopefully it shows 14.7 or so and that way I KNOW its a wiring issue with the EIO.
This is just getting annoying.......
Old May 16, 2006 | 11:02 PM
Black02SS's Avatar
You have the worst luck.
Old May 17, 2006 | 04:55 AM
99whitews6's Avatar
Yeah. First thing I tried was to unhook the WB, power and LC-1 and then do a full recal. Nothing changed....I will see what logworks is reading today and go from there. Everything was working great and then this
Old May 17, 2006 | 02:43 PM
99whitews6's Avatar
Ok, I am not sure what it is now
Car Running:
-If I watch it through logworks V2 it reads perfect. Once the car goes to closed loop it jumps right to 14.7:1 .
Car Running:
-If I turn on HPtuners it wont move from 20.4X-20.6X. If I log raw voltage through hptuners it reads 4.3-4.4 Volts. If I turn the WB off and then look at HPtuners it reads 1.3-1.4 Volts. (note, this voltage value is not affected if the ground wire going to the EIO is connected or not)
Key OFF Position:
-If I just take the analog "IN" line from the LC-1 it reads like 0.8 volts on a DMM while warming up and 3.0 volts once heatup is complete.
Car Running with Key in ON Position:
-If I just take the analog "IN" line from the LC-1 it (DMM) reads 4.4 once warmed up.
Note: this is a brand new MPVI EIO that i have been using for a month and it has been working fine.
Old May 17, 2006 | 06:19 PM
soundengineer's Avatar
your LC1 is bad....
most likely the output DAC
how do you have it wired up..
tell me where every wire is connected
Old May 17, 2006 | 06:46 PM
99whitews6's Avatar
Originally Posted by soundengineer
your LC1 is bad....
Damn LC-1 better not be bad! I just got done upgrading to MPVI EIO!
I dont have it in front of me but I believe:
Heater Ground --> Chassis Ground
All other LC-1 grounds go to EIO black wire (ground)
Analog output 2 goes to EIO
Power comes right off battery, through a fuse, and through a switch
Calibration wire goes to EIO ground in parallel with LED and Momentary Switch. It has been working fine for a couple of weeks so I would assume that I have the wiring right.
Could I just use analog output 2 from LC-1?
DAMMIT!
Old May 18, 2006 | 12:08 AM
cantdrv65's Avatar
Post
I have ALL of my grounds going to chassis ground. I ran one ground for analog 2 to the EFIlive interface from the same chassis ground. No problems here.
Old May 18, 2006 | 12:25 AM
TT_Vert's Avatar
seems there are nothing but problems w/ the LC1. I kinda want my LM1 back again. Bulky yes, but it worked ALWAYS..
dave
Old May 18, 2006 | 08:51 AM
dissonance's Avatar
I'm having the same problem... Logworks shows current AFR but analog 2 has a fixed voltage output “4.5 to 4.7” and just like yours it just started acting one day. But the analog 1 “narrowband” is reading just fine and that leads me believe the DAC is working on mine. I have talked to innovate about this and they confirmed there is only one DAC in the lc-1 so if it was the DAC the output for both would be out of rang
So I would test the analog 1 and see what output you get, I haven’t had the time to work on mine more. Plus I’m out the warranty.
here is my post on innovates site
http://www.innovatemotorsports.com/f...ead.php?t=3274
