Security light causes car to not start
ok the security light stays on and the car wont start, i have to wait 4-5 minutes to start the car everytime i shut it off. I have to tunr the key and then turn it off then wait 4-5 minutes for the light to turn off. then the car will start. I thoguht it was the battery so i got a new battery, started up great the first time, then it started doing it again, i thoguht it might be the key, so i used the spare key i have and it did it too. I was told that it might be the ignition modual, or ignition tumbler?? any help on this would be great. Thanks
You can search for the by pass method also. Get a set of resistors the same value as the pellet on your key.
then you wire it inline to the passkey harness at the column. This will by pass the pellet reading section of the lock cylinder & the car will start normally.
There are 2 wires. One has a 5 volt reference, the other is the return voltage back to the BCM thru the resistor. The amount of the voltage is dependant upon the amount of resistance in your key. That is basically how it works.
That should give you a reading. The resistance values are usually under 25,000 ohm I believe (25K)
Then you can pull the lower column apart, the panels etc. You will see a orange wrapped 2 wire harness w/ 2 small 20 gauge white wires inside. This is the pass key/ vats system harness to the lock cylinder.
You can cut into it or what ever, Just be sure you have the right harness. Air bag harnesses are yellow, so if your color blind dont f-up! J/K
