Partial throttle tuning
I think I can kind of tell then things are running well. The engine sounds more angry and leads the throttle. When timing is out, it lags the throttle and sounds muted. You can check against KR, but the best thing is to try different base tunes. You will soon "feel" when it is running better. Might not feel any faster but will appear to the ear as more aggressive.
When looking at timing and you see knock retard do you assume its going to be reading from the low octane table? I will be using high octaine fuel in a few months, just tuning for the lower octaine, which is rated at 95 RON, hopeing I can tune the low octane table for the cheaper stuff, and then work on the high octane table later this year. So my question is, if the knock sensors detect knock does the PCM start using the low octane table?
after each time I would pull up the spark retard
histogram, max view (HPTuners) and where I saw
retard took out two degrees while where I saw
none, added one. This all won't work well unless
you settle down the KR attack/decay but if you
do it will make the actual knock-point more clear.
Enough of this and I had a timing table and a
resulting log histogram where I hit 1 degree of KR
in almost every cell. Subtract 3 degrees across
the map and there you are, right on MBT. Then
past it to the LO table and take out another 4
there for bad gas and bad weather.
I'm going to start using the high octane gas soon, only 1 in 5 gas stations does the one I want, its 99.9 pence per litre = $8.16 dollars per gallon. The cheaper stuff I use is only about $0.60 per galon cheaper, so its not a lot of difference. I'm not complaining about cost as having this car is well worth it.
Soon I'll get this knock retard under control. Got the AFR pretty spot on across the board. I should have sorted out the knock retard before, nearly alays get knock above 4000rpm, took out a few degrees today and got no knock.
I contacted Texas speed about getting a cam shipped to England, but no response yet. I'll give it another go. I and still learning about cams, and in comparison the MS4 looks great, almost too good to be true. Still retains some power fairly low down in the RPM.
This MS4 cam claims to add 80hp, now that sounds great, just hope it passes the emmisions sniffer test. If my AFR stays between 13.6 and 15.6 during the test then it passes, they looks for a couple of other gasses to, I'm hoping all will e fine, its quite a relaxed emmisions test, I choose the RPM that they test at so we can get it through the test. :O)
I agree with Guits a big cam will fail. AFR has to read 15:1 to 14.4:1 at all test points. Overlap might mess with that too much. Also CO and HC emissions are checked. I dont think its too strenuous, but Ive not seen a definitive answer as to what cam will pass. Im running a 220/224 just in case. If I knew it would pass Id be using an F13 or big lift 224/228 for sure.
I havn't found the cam numbers for the MS4, but the MS3 is 237/242. I am aware the higher the numbers the worse it is for emmisions. Why?, okay it seems like a newb question, but okay, there will probably be overlap when both valves are open at the same time, why would this cause problem with burning the fuel. As emmsions are measureing if the fuel is burt properly, and not too much air or fuel in the gases too. The idle will be lumpy, which is what I am after, but if I tuned it and ran the emmisoins test at say 2000rpm surely its possible to get it through. To get more power from the engine, which the cam does, is to make your engine more efficient, making more power from the fuel and air you are putting in, okay the cam is letting in more air, therefore you dump in more fuel. I'm know it does/can cause a problem with emmisions, I just wondered if there is an explaination.
Sorry, I ran away with someone's thread.
Hi Ringram, Good to hear from someone also in England. We have problably met at a show some time in the past, did you go to Wheelsday in Aldershot?
I'll have a look for abbeymotorsports.
On my last MOT I thought it said the Lambda had to be between .9 and 1.1 lamda. Thats 13.15 - 16.00 AFR, I could be wrong, I'll check my certificate again. It may have been 0.95 and 1.05 that would make 13.89 - 15.35, still a good range to hit. But as you say the CO and HC have to be good, last time I was at least 10 times under the limit on these two.
Yeah I guess it stops you running lean to pass and upping NOx emissions.
The gas limit is around CO<=0.3%, HC<=200ppm
I remember i was 20ppm on HC and 0.01% on CO last year.
I wonder what cam I can get away with. I like to be dareing, I wouldn't mind trying a 224/228 and a nice lumpy idle too.
