I'm throwing these codes, what are they?
We found that 0430 is the rear O2 sensor, understandable for the catless pipes. The 0181 is for Fuel Temperature Sensor A Circuit Range/Performance.
What is that?
0765 is a shift solenoid, and
0040 is O2 Sensor Signals Swapped Bank 1 Sensor /Bank 2 Sensor 1.
How do I fix these?...basically that is my question.
I was just worried about the fuel temperature one, but it seems like there's no problem as we just rode around for about an hour with the scanner hooked up and all was well.
I don't know if it throws faulty codes at times, or what.
I'll ask if they come back tomorrow, don't think they will, but I just thought the whole thing was pretty suprising.
0430 is Catalyst system low efficiency Bank 2
0181 ? i guess its what you said
and for the rest of em'
what all sensors did you take off and re-plug after the install? what sensors did your rub by? I mean it really could be anything. Sometimes it just has issues and then corrects itself, or sees someting new and corrects for it. all i can say to do is check all the things you unplugged and make sure they are in their original plug and make sure no grease/water/ or other object is on the pins connecting the sensors
