Speed density tune????
hit search on the left side of the screen
type in 2bar (just like that with out the space)
click on GM > Operating System
or if you want to do it with the tree it is
Working with VCM Editor >> Parameters -GM >> Operating System
hope that helps
Mike
good post. it takes alot of data logging to cover all the bases but if you are patient and understand the internal combustion engine, its fairly straightforward. at any one point in load, rpm, boost, and temp, the engine only needs one amount of fuel. might seem simple, but add those number of variables up and there is alot of tuning to do. Once you get some of it down you can make an educated guess and tune on the safe side on the rest of the areas, then start logging when you get the time. Personally its hard for me to tune for cool weather, how the hell am I going to tune something for 30 degree weather when there is about 5 hours PER YEAR that it gets that cold down here? LOL. So I just need to make an educated guess and tune on the safe side for the cold. Humidity never really seemed to be an issue for me, and we have plenty of it
I also think jake makes a great point. tuning the fuel curve "guessing" with a FI application is asking for trouble. the technology is there and easily accessable, why not use it?
