LM Programmer
Old Jul 17, 2006 | 04:05 PM
Sport Side's Avatar
Default LM Programmer
I downloaded LM 2.02 for my LM-1 and am trying to set up the manager to read correctly with the HP Tuners.
I have a raw voltage so, there are no problems here.
I tried leaving it with the stock settings for A/F and even in Lamda... With this, I get no correlation between the LM-1 (which is accurate) and the Input reading with HPT.
I thought it was 1-5 V for 10-20 AFR... Am I wrong? Set this way, the input on HPT wants to read 19.38 and doesn't vary much from what I'm looking at. LM-1 output shows 14.7 for example while this is occuring.
Old Jul 17, 2006 | 04:11 PM
horist's Avatar
verify the settings w/the serial cable (LM-1 side)
I believe the PID included w/HPT is 0-5 volts = 10-20 AFR
I've created my own custom PID to log 0-5 volts is 10-16 AFR (beyond 16 I'm so lean it doesn't help w/tuning) (configured the same for LM-1)
however, that reading in HPT even if it was misconfigured doesn't seem right...
Sounds like the LM-1 isn't configured correctly ... log raw voltage in the HP Tuners Scanner and see what the actual voltage HPT is receiving is
Old Jul 17, 2006 | 04:25 PM
Sport Side's Avatar
Do I need to configure raw voltage? I thought I remember seeing that you were able to under the help file.
Old Jul 18, 2006 | 03:28 PM
98Z28CobraKiller's Avatar
Restricted User
Do you have the HPT EIO or are you doing it thru the EGR? If thru the EGR, then there is a PID for EGR voltage that will give you the reading that the EGR is seeing at the brown wire. I don't have the EIO so I am not sure how to get the voltage reading that is going directly thru the IO interface.
Old Jul 19, 2006 | 12:18 PM
Restricted User
I just got my serial cable and took a look at the Analog output default and it was set with a range of .1V to 1.5V. I changed the range to 0V-5V 10-18AFR and my logging thru the egr is working great.
Old Jul 23, 2006 | 04:28 PM
Sport Side's Avatar
I'm using the EIO... Set to 0-5 V = 10-20 AFR, it is still not reading accurately. It seems to poke around 17.5 AFR while the LM-1 reads 14.7.
Raw voltage is roughly 1.9-2.0.
Any ideas? I can not get these two things to line up.
Old Jul 24, 2006 | 05:15 PM
Sport Side's Avatar
One TTT before I give up on this...
Old Jul 24, 2006 | 07:28 PM
horist's Avatar
how's it look during normal driving? aftermarket cams can cause false lean condiitions at idle
Old Jul 24, 2006 | 07:35 PM
Sport Side's Avatar
I need to try that... I've just been sitting in the driveway each time. I still don't understand why the two (LM-1 and HPT display) do not show the exact same A/F... Why would one display lean and not the other.... LOL
Old Jul 24, 2006 | 07:45 PM
foff667's Avatar
LS1TECH Sponsor
can you post an hpl file or send it to me & I'll host it...just so we can see whats going on.
Old Jul 24, 2006 | 08:48 PM
Restricted User
What equation are you using for the PID that you created? You could just have incorrect values. Is it consistent. Likealways the same that it is off by.
Old Jul 24, 2006 | 09:18 PM
foff667's Avatar
LS1TECH Sponsor
from what he told me he's using the preconfigured one...he and I have the same setup so I was trying to help him via pm.
Old Jul 24, 2006 | 11:06 PM
Sport Side's Avatar
Yeah, let me see if I can throw a log on here... HMM, actually I don't think I have one saved... I usually slam the lap top shut everytime I see the values are not inline. LOL
And to give you an idea. When it is programmed correctly (0-5 = 10-20), the values will vary as if some sort of formula is just not being setup correctly... Weird because I'm using the 0-5 = 10-20 which would set it up the right way... IDK
