Paging fof667 or soundengineer
I need some help with my A4 car. It has a FLT Level IV trans (vacuum modulated) and Yank PT4000 with 3.73's. Both are new with approximately 1000 miles. I use EFILive for tuning.
Here's the main problem. When cruising at a steady speed between 50-60 mph and I go WOT there is a short delay (read: deadspot) before the TC lock up is released and the trans downshifts to 3rd gear. It seems no matter what I do to adjust it, the problem is still there.
I'm also getting some bucking right after the TC locks up in 4th gear about 44-45 mph. It doesn't happen if the TPS progressively goes higher and the car keeps accelerating, only when it locks up and stays a constant 44-45 mph.
Any help is appreciated.
i would recommend PMing him or IMing him to get in touch with him as i suppose he is very busy right now.
As for the dead spot, have you tweaked your mph tables any?
the bucking is a surging issue...the easiest way is to adjust your lock & unlock tables to it never hits the trouble spots...also there are a few threads on here about dealing with surging and its curesas for the dead spot I would really have to drive the car to feel what your feeling to be honest...hard to internet diagnose things like that, but if the car isnt shifting where & when you tell it to its rarely a computer problem.
As for the surging, just tune it out. That's the only option i'm aware of.
The throttle cable has some slack in it to the point if I go WOT and let off right it away it will pop off the TB cam. It's a non-TCS car, so it's not adjustable. I'm going to check that.
Thanks.
I agree with qwik.
