Higher Wattage O2 Sensor Part #?
Old Sep 11, 2006 | 11:31 AM
superls1's Avatar
Default Higher Wattage O2 Sensor Part #?
Can't get search to work. Tried several different times, terms, ...
At one point, I had this info. Generally, I was under the impression the vette rear O2's were higher wattage. Therefore, they were less susceptible to the switching error codes (P1133/53, etc). However, I was told today that some of the vette years had lower wattage O2 sensors in the rear location.
So, I want to ensure that I buy the higher wattage ones. Anybody know for certain the part number? Also, are there higher wattage ones with the correct connector? Some are square vs flat. Thanks.
Old Sep 11, 2006 | 12:00 PM
Patrick G's Avatar
LS1 Tech Administrator
Bosch 13111 Corvette rear O2 sensors have the highest wattage from what I understand.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Sep 11, 2006 | 12:21 PM
SSpdDmon's Avatar
See the thread you created over at EFILive. Gave you pt #'s for AC Delco, NGK, Denso, and Bosch.
Old Sep 11, 2006 | 12:34 PM
ChrisS@sdpc's Avatar
Thanks. Are the connectors on the O2 square or flat? Are the front O2 plugs (to the PCM) flat, but the rear O2 sensors are square? Don't have any with me.
Old Sep 11, 2006 | 12:42 PM
SSpdDmon's Avatar
They are all square connectors on LS1 cars...
Old Sep 11, 2006 | 01:06 PM
Thanks for the quick response. I guess I have some older O2's lying around. I thought somebody was making connectors that converted the 4 pin flat to 4 pin square, but I guess it is not necessary.
Old Sep 11, 2006 | 03:33 PM
brentg454's Avatar
Not true... My 2000 C5 has flat ones on the front and square ones on the rear. LG motorsports has the adapters to let you run the rears up front, and I think Casper Electronics has them, too. HTH
Old Sep 11, 2006 | 05:39 PM
SSpdDmon's Avatar
Meant f-cars...sorry
Old Sep 14, 2006 | 03:43 PM
superls1's Avatar
Yep, I thought that the fronts were flat. Can't believe what some people want to charge for the adapters.
