HPtuners shows TPS at 100% but the TB is stock???
ok when i did a WOT while scanning i looken at the TPS and it showed like right at the 100% mark but i haven't done any bump stop grinding or anything i thought that they only did like 95% stock but i was just wondering thanks for any help in advance.
if it didnt hit 100% that would be completely pointless... 100% is a relative number, you can tune it to read 100% if your throttle is only open 30 degrees. basically its tuned so minimum throttle position is 0% and maximum is 100%.. whatever those positions may actually be is not determined by TPS readings.
on another note.. grind away the stops so you can turn the TB farther than 90 degrees... if 90 is good, 180 is better!!! double the airflow!!! (kidding of course..)
Moderator
Manufacturing slop means everybody's TB is going
to differ. You want to get full mechanical open by
a mechanical measurement and then just be sure
that the voltage is still within acceptable range.
