Random Misfire with no codes
Old Oct 15, 2006 | 06:55 PM
wm_sorg's Avatar
Default Random Misfire with no codes
I have been getting random misfires under normal driving conditions. Mostly crusing, lugging and loafing. The engine does not misfire at high rpm or under hard acceloration. The problem does not seem to be temp related. Fuel pump and filter have been replaced. However it seems to behave like it's starving for fuel. Any thoughts?
Old Oct 15, 2006 | 07:05 PM
2001NBMZ28's Avatar
No codes? Random misfires is P0300. You mean exhaust popping a little?
Old Oct 16, 2006 | 10:38 AM
wm_sorg's Avatar
No. It's more like a cough with no backfire.
Old Oct 16, 2006 | 04:34 PM
Streetracer361's Avatar
Having close to the same problum, would like to know also what the problum is. Bump for you.
Old Oct 16, 2006 | 06:12 PM
XpertWS6's Avatar
Default missfire
check your spark plugs and resistance on plug wires,clean throttle body,clean maf sensor.
good luck
Old Oct 16, 2006 | 07:33 PM
wm_sorg's Avatar
Maf is clean. Engine has less than 10K on it. What should the resistance measure?
Old Oct 17, 2006 | 08:11 PM
BoostedWS7's Avatar
would too cold of a plug do it?
Old Oct 17, 2006 | 08:16 PM
Doc's Avatar
Doc
More details about your setup. Sounds like it is new. Elaborate on the "behaves like it's starving for fuel" do you have any evidence to back that up? Wideband? M6, A4, converter size? Many things, need details to zero in.
Old Oct 17, 2006 | 08:23 PM
TransAminal's Avatar
Sounds like something spark related. Thats what my car used to do when the plugs were going out after 80K miles. It would stumble under any throttle application at low RPM's, but in the higher RPMs the issue wasn't there. Basically I think the spark wasn't strong enough to ignite the rich mixture under a load at lower RPMs.
I'd replace the plugs and wires first off. Use either stock AC Delco wires or Granatelli zero resistance wires (thats what I used and they are excellent). For plugs I used AC Delco Iridiums, I think they are the best for our engines, and have virtually no gap erosion even after 100K miles.
If the misfire is still there after you change the plugs and wires, I'd suspect a bad coil or a fuel issue.
Old Oct 17, 2006 | 08:48 PM
wm_sorg's Avatar
Unfortunately no log files. I am looking into a software solution. The car has a mild cam with tune a4 with yank SS3600. The problem literally developed overnight. Car ran great. Parked it and next day less than a mile from home it started. Seems to stumble under cruise. If I open the throttle it somewhat helps clear it past the dead spot. The dead spot is random. If I get VCM software will it help me diagnose even though PCM does not detect fault?
Old Oct 24, 2007 | 03:49 PM
solowls1's Avatar
any one figure this out havin the same prob basically
Old Oct 24, 2007 | 03:54 PM
3.4camaro's Avatar
Check for vacuum leaks, make sure your injectors are all plugged in and working, and make sure all you plugs are firing. Most likely vacuum leak.
Old Oct 24, 2007 | 04:28 PM
2002_Z28_Six_Speed's Avatar
Is it a 98? Sometimes with a converter it will randomly misfire unless you detune the knock sensors.
I think changing the harmonic balancer can also do that.
Old Oct 24, 2007 | 05:51 PM
jimmyblue's Avatar
Moderator
You can have a random-seeming miss when something is the
"tip of the iceberg" and you're just barely tickling the problem.
Like one weak cylinder (injector lean, maybe) and then the
proportional fueling as it wanders around, stumbles when it's
swinging lean and that cylinder is up to bat. Or something.
Hard to diagnose these cars without the tools because there
are so many wheels within wheels. Not like carbs where it all
came through the same big hole pretty much.
Ignition problems usually manifest worst / first at high load.
I'd be inclined to chase a light-load, closed loop miss through
the fuel delivery and air metering paths first.
Old Oct 24, 2007 | 06:20 PM
Toes's Avatar
possible your fuel regulator is leaking fuel back into the intake through the vacuum line? does it start hard like you have to put your foot into it to get it to fire?
Old Oct 25, 2007 | 12:46 PM
wait4me's Avatar
Efilive has a scan tool that is only 250 bucks. It allows you to do cly balance tests and allows you to see all the enhanced perameters on your car. You can watch each cyl individually and see exactly what cly has the issue. That problem is usually a 10 minute issue to figure out exactly what is wrong.
Old Oct 25, 2007 | 09:11 PM
solowls1's Avatar
well i tried a diff maf , im goin to try a new set of injectors tomorrow. how would u know if the regulator is leakin it back into the manifold. plus i put new o2 in today all so ...most time if it does die it you do have to give it gas to get it to fire back up. it did the same thing on my old motor and i put a new 408 stoker in it bout 3 months ago and same thing so .....
Old Mar 20, 2015 | 05:57 PM
WSSexy's Avatar
Did you ever find a solution to the miss? I know the post is old but I'm having a similar issue
Old Mar 20, 2015 | 06:09 PM
Pulse_GTO's Avatar
The op has not logged in in years. Could also be a ground issue.
