Will I need a tune?
Old Nov 23, 2006 | 03:18 PM
Wheeler99WS6's Avatar
Default Will I need a tune?
I am thinking getting Torque Converter next, probably around 3500 stall and was wondering if I Will need a tune if I am adding only a Torque Converter.
Old Nov 23, 2006 | 03:44 PM
Jon7I2's Avatar
I would imagine that u would need a tune. But im an M6 guy so i dont know for sure.
Old Nov 23, 2006 | 04:21 PM
Rhino79's Avatar
I think you will need to disable the abuse mode because the pcm will think its slipping with the new converter and some have to adjust the Misfire tables to correct converter locking/unlocking issues.
Old Nov 23, 2006 | 05:11 PM
2001NBMZ28's Avatar
Depending on the TC might find you want to bump the line pressure up a little and increase the in gear idle speed some too - my idle wanted to "hunt" sometimes coming to a stop and at low speeds, like in parking lots. Did both and also deleted TM completely on my car - no locking/unlocking issues in my case. Not trying to scare you away, just saying you might need some tuning.
Old Nov 23, 2006 | 06:37 PM
foff667's Avatar
LS1TECH Sponsor
when I had my TCI3500 the ONLY thing I really would've done was change my 2-3 shift pattern at wot because it would hit the rev limiter on that shift without tuning...other then that I had not one single issue & even on the stock tuning went 6 tenths quicker at the track before/after.
Old Nov 24, 2006 | 11:46 AM
hmm. well maybe I wont install it until I get a cam and gears. So I can minimize the amount of times I have my car tuned.
Old Nov 24, 2006 | 11:58 AM
foff667's Avatar
LS1TECH Sponsor
or you could consider purchasing tuning software of your own so you don't have to worry about doing 3, 4 or 5 installs at once and can do them at your own pace...setting up things like gear ratios & wot shift points are the easiest & most strait forward part of tuning
Old Nov 24, 2006 | 12:01 PM
Black02SS's Avatar
If you want to save some money, like foff said, purchase your own program. Right now I am offering a full tuning package for $660. I would be more then happy to get your file setup and everything runing for you as well as in the future when you get more mods. For the price it is a wonderful investment.
Old Nov 24, 2006 | 12:03 PM
98redorangeta's Avatar
When I put my 3400 stall in i didnt really NEED any tuning only problem i ever had was once in a while backing up out of a parking spot it would die but you can change your driving a little to get around it f corse i have tuning softwear so i fixed the problem and didnt have to worry about it but i didnt NEED the tuning its some thing you cand deal with.
Old Nov 24, 2006 | 12:26 PM
I would love to have my own tuning software but clueless on how it is designed to work and I would probably mess it up rather than fixing anything. I am leaning towards a Custom tuned PCM from Nelson performance. I hear that guy can flat *** tune.
Old Nov 24, 2006 | 12:38 PM
foff667's Avatar
LS1TECH Sponsor
with hptuners comprehensive help files, dozens of flash demos & our support forum with over 5000 members now theres usually someone that will help you in your quest. Tuning really isnt that difficult & HPTuners is probably the most user friendly software available today making things that much easier.
Old Nov 24, 2006 | 12:45 PM
Black02SS's Avatar
EFILive offers a demo you can download and try. HPT doesn't. That should speak for itself. Flash demo isn't the same as actually being able to use the software and see what things are about. I am asking HPT once again to release a demo like EFILive does. This will stop the bickering on the forums as then the people can get a first hand experience on what THEY like better, not what people tell them they should buy.
