Can't get 2bar EFI Live to run more than 3 seconds.
Coal Mining Director
Installed a gm 12580698 2bar. Unplugged the maf.
Downloaded a 2bar starter tune. Verified key on engine off = 94kPa.
No DTC's
Car starts and idles smoothly for 3 seconds and shuts off.
Any ideas? TIA.
No DTC's
Any ideas? TIA.
LS1 Tech Administrator
Probably a dumb question. Did you set the MAF high frequency fail to 0?
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic210_1.gif)
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
After you rescaled the map scaler for the 2 bar did you check it again? Also what "starter" tune are you talking about? You might be better off using the tutorial and starting from scratch.
What kind of setup do you have?
Howard
Howard
Howard
Howard
I bought a Moates RR from Jes Bubb and he kindly set up a COS5 starter tune since my original OS is 1999. I'd hate to start from scratch since the 1999 has to be hand loaded...but I might have to.
Black02SS has been very helpful also with trouble shooting suggestions.
set-up is a twin turbo 428 ci Firebird.
The last file I sent you is COS5 with the SAME values as the other tune of yours that runs. I went through and manually copied over every table/cell to the new one. This will tell me if some of your tables need to be reset due to not having a MAF. Did you get a chance to try that last tune I sent?
Check the Axxx Custom values, wrong values or DEFAULT values in there can cause that. Also I had a similar problem it was due to old .cal files messing with me. Check your cal files are up to date.
Originally Posted by wait4me
I might have started with a pre beta os5 and the file wasnt set up internally to run on the roadrunner. ? I would just try transfering the Cal changes over to the latest os release for the 05.
Just tried that. I have a COS5 that will start in the RR.
I flashed your cal into it....does the same thing ...idles 3 seconds and dies...somethings wrong with the cal file
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
The safety checksum is not dissabled in it so the computer will shut my cal down. Just manually transfer over all the tables that are different one by one to the file that works..
When I do a compare to another tune, sometimes a different set of numbers appear in the table.....strange...almost like a ghost overwrite...
