2-Step in HP tuners???
Old Dec 19, 2006 | 03:39 PM
BADSZ28's Avatar
Default 2-Step in HP tuners???
I posted this up a long time ago and did not get much back on it. I figured I would try again since it has been out for a while with lots of people doing new and different things with it.
My question is, is it possible to trick the PCM into performing a 2-step function? On HP tuners forum a guy with a V6 car did it. How about us V-8 cars? My thoughts were to tap into the NSS pinout in the PCM and turn on the PRNDL and setting rev limiters acordingly. Any thoughts or suggestions? Maybe experiences? There has to be a way to make this work. This would be for an M6 car.
Old Dec 19, 2006 | 03:50 PM
SShawn's Avatar
by 2 step u mean igniting fuel in the exhaust to spool the turbo early right? or am i on a different page
Old Dec 20, 2006 | 12:06 AM
02 BLK WS6's Avatar
Different page bro. I don't know about this though, there are a couple of guys running a Harlan 2 step around STL.
Old Dec 20, 2006 | 12:31 AM
SShawn's Avatar
http://www.hptuners.com/forum/showthread.php?t=587
that help?
Old Dec 20, 2006 | 12:34 AM
SShawn's Avatar
yea i had my **** mixed up, i have an idea what a 2 step does, but obviously not a very complete one haha.
2 steps are only for turbo cars thought right? its my understanding that it is used to spool the turbo while the car is at a stand still.
::edit::
Originally Posted by MrDude_1
no fuel = no burn in the exhaust... no burn = slower/less turbo spooling...
with a conventional 2step, the fuel ends up burning in the exhaust, so the volume in the exhaust is still like WOT, keeping that turbo spooled up good..
this 2step only sounds like a solution for N/A guys.. mostly manuals, but i suppose someone with a large stall and a transbrake could use it to launch from a less then true stall RPM...
thats the 2 step i was talking about, but im reading about it also being used as a rev limiter to have consistant launches. which do you mean?
Old Dec 20, 2006 | 08:39 AM
BADSZ28's Avatar
I want to use it as a rev limiter for launching. I know the PCM cuts off fuel and that is fine.
Old Dec 20, 2006 | 09:01 AM
BADSZ28's Avatar
I tried this with no luck. Seems some have done it though. Must be overlooking something.
Old Dec 20, 2006 | 10:27 AM
02 BLK WS6's Avatar
Pretty sure a 2 step can change the firing order instead of cutting fuel (running lean) to say keep rev at about 4.5k or so. Flip the switch and revs to the moon and you launch.
Old Jan 4, 2007 | 01:37 PM
BADSZ28's Avatar
Anyone else?
Old Jan 4, 2007 | 05:46 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
A good two-step cuts spark randomly to multiple cylinders to maintain a desired rpm, even at WOT. The reason for varying cylinders is to keep from loading up/fouling out cylinders during this process. You can achieve a half-assed two step with the P/N rev limit fuel cutoff in HPT, but the response time is so slow that you can't maintain a steady rpm. For N/A cars, a two step can provide a consistent launch rpm. For centrifugal cars with an auto, it can keep from pulling through the converter's stall speed and overheating the tranny at the start line. For turbo cars, having the throttle wide open allows the turbo to build boost, which is enhanced by the raw fuel expanding(burning?) in the exhaust pipe. A good spark cut rev limiter cannot be used on a car with cats, as they will quickly overheat and come apart.
Old Jan 5, 2007 | 08:41 AM
BADSZ28's Avatar
Seams like a true 2-step or stutter box is the way to go.
Old Apr 9, 2008 | 12:41 PM
BADSZ28's Avatar
Just want to bring this back up to see if anyone has done this with success.
