Few things about tuning for a turbo
First I see that my map sensor is maxing out. I have been told that I dont need to get a 2 bar sensor unless im doing a speed density tune.
Is there any reason why I can install the 2bar map sensor so that I can see my ltfts and stfts so I can see if they are sticking at 0's....
Also so that I can log my a/f ratio in that range with my wideband..
I assume I will need 2bar support with hptuners to log that 105kpa+ area as well.
Now tuning the ve table in sd mode planning to hook the maf back up..
It is correct that I only need to log 50+ hits for all cells under 4k rpms correct?
What If I do SD mode, do I need to hit all cells? Is that safe?
Also with a turbo how high in the freq do I need to lot to with a turbo? Past 10k? How many counts per cell do I need to hit..
Another problem I am having is when I log with wideband and use the a/f error.. I get everything looking good and the next day I do some more to make sure it looks good and the ltfts's and stfts's look good but the a/f error is off? WHY? Location or inaccuracy of wideband?
I have done the ve table and calibrated the maf... However when I plug in the maf it seems to want to put everything positive..
Maybe the MAF is going bad?
I have calibrated it many other times for n/a without a problem..
Actually tuned my car and others without problems before but the turbo is causing me problems..
I havent seen many writeups for turbo tuning.
I upped my ve tables around the 3200rpm and 60g/cy to 105+ and changed my pe around the 1.5xx range across and its still wanting to go lean under wot..
PS.. Im at work right now.. Ill post me tune and some logs if anyone can help out. Thanks and feel free to point me torward any turbo tuning guides...
I just found some stuff redhardsupra has done but havent had time to look at them yet..
at only 5psi you will reach roughly 135.7893 kPa; which is 483.87 g/s of air on the MAF.(Could be more...could be less) but it is close to the 511.99 g/s capability of the MAF. You will max out your VE table and MAP sensor, BUT you will still have your MAF table and PE table adding fuel to your car. Try raising your MAF numbers more( if not maxed out), and if your upper limits are already at 512 and you are reaching that, increase your PE table even higher and get back with me on your lean condition.
I honestly see no need for SD at 5psi
QUOTE:
MAF simply maxes out at 56lb/min, so the airflow number becomes a constant. END QUOTE
(512 g/s) / (453.6 g/lb) = 1.128747795 lb/s of air. which
1.1287 lb/s * 60 sec/1min = 67.722 lb/min
or did I do a calculation wrong?
453g/sec==60lb/min
426g/sec==56lb/min which is about max what i've seen on a MAF
I haven't seen MAF being useful past ~56-59lb/min (i've seen it go flat on different cars in this range)
453g/sec==60lb/min
Appreciate the info on the ve maxing out. Didnt know that.. Ill work more with the maf and pe table to see if I cant bring it down to the 11's afr..
and 59lb/min is 0.98333 lb/s .... and 13.111 cubic ft/s and 454.96 g/s...
well.....i guess i will see how this turns out on mine, and if i can get it not to flatline at my 5psi (62.8 lb/min.....1.04667lb/s ...you get the picture... 484.26g/s) I'll post what i did. but I'm going to bet that it will in some way flatline and not work as others have seen
This was a month and something ago, when I had a single pump (and meth) that was running out a bit up top (cheated PE for FP drop before the second pump went in). It was preliminary WOT tuning @ about 11psi. In g/sec it showed 511.99; I changed the labeling over to lb/min since that's what the discussion was here:
Which leads to my next question.... If I log raw frequency why does it continue to climb AFTER that point? I am at 15.5 psi and about 17deg timing now on the street and the MAF curve goes straight up to max in the early 4K RPM area and yet the raw frequency logged seems valid.... If I plot it against the curve on a spreadsheet it seems that the MAF is still reading but we are at the limit of the PCM's input. Thoughts?
I think Frost has a point in that the original assembly was written to facilitate the needs of a factory engine so they didn't code beyond that original 9 bit integer. Or perhaps anything higher is out of the spec range for the maf's design parameters so they don't rely on it above that point?. I'd be curious to see a datasheet on the maf.
Anyone have the original GM source? lol
