Secondary VE?
)So I am set up to start logging my fuel trims to tune my VE. I have done all the stuff to put me in SD mode. I was doing some more reading to understand things better and now I have a question on which VE table do I modify, secondary or primary? Apparently my car will fall into the secondary VE when I go to SD mode. So doesn't that make tuning the primary VE useless? Once I adjust the primary VE via the logged histograms, then reflash the PCM, nothing is going to happen because the car will not be using the primary anyways? So how do I go about tuning these tables?
I will be re-enabling the MAF as well when I am done.
Thanks to anyone who can straighten out my confusion
- Start the HPT Editor & open SDStarter1.hpt
- Start the HPT Scanner & open and open SDtune1.hpl
- Open your pre-configured AFR error % histogram & set cell his required to 50, click average & load all data.
- Next highlight & copy all cells
- Switch to the SDStarter1.hpt file & open your main & secondary VE tables & paste special-multiply by % to the main & hand blend the surrounding unaffected cells. Then copy each line to the secondary.
- Now Save your tune as: SDtune1.hpt & perform a calibration only reflash to the PCM
- If necessary repeat the until the average cell values in your AFR error map(s) are close to 0 (aim for +/- 1%).
- At this point if you have completely removed your MAF & have made the decision to never use it again you are done and can go about your way. If you are going to put your MAF back on keep reading.
None of the write-up's that I have read deal with tuning the secondary VE, just the primary. I understand the steps in the process but cannot see how to get there with two VE tables......
(I realize there are more details in the logging and tuning process, but I am just trying to get to the point
)I beginning not to like two VE tables very much........
Why would you use a WB on FI but not on NA?
So I am going to have to tune by copying and pasting my fuel trims into the secondary VE. (Since the primary is being ignored in SD.) Then copy those values into the related primary VE. Then re-log go through the same process. Then hand smooth the graphs at the end of it all when my trims are good? Is this going to work out ok when I enable the MAF? 2. take corrected primary VE table copy-paste into that excel file I posted
3. copy new secondary VE table that the excel file produces for you
4. paste new secondary VE table into the hptuners editor.
5. load new tune
6. rinse, repeat.
5. load new tune
6. rinse, repeat.
Thanks for everyone's help, much appreciated!
