07 tb ss problems
Old Jan 18, 2007 | 05:10 PM
fast98's Avatar
Default 07 tb ss problems
ok so this is my buddies truck. it read the tune fine, but when i went to right a calibration it failed so i had to do a write entire. well the first problem is that everytime i wanna upload i gotta do a write entire, the second problem is that every once in a while you will go start up the truck after its sat all night and you go to pull out into traffic and theres no throttle response, feels like the tans has defaulted to 3rd gear, cause when you get going faster it feels fine. the way you fix this is to move the gear selector to neutral then back to drive. anyways i was just wondering if anyone else has these problems. thanks guys
edit: i have hptuners mpvi version 2.1.14
Old Jan 18, 2007 | 07:18 PM
Blades's Avatar
I haven't had any problems with that. My truck is a 06 TBSS.. They do have different tuning. What exactly did you change?
Old Jan 18, 2007 | 08:17 PM
fast98's Avatar
a bunch of stuff, the only mod to the truck is a k and n intake. tq mgt, spark tables, pe stuff, dfco stuff, maf tables, wot shift tables, shift pressure tables. maybe a few more things, but i cant remember.
Old Jan 18, 2007 | 08:20 PM
Sean Collins's Avatar
The know it all's know it all
Have dealer or friend reflash with tech2 to stock tune. Sounds like somthing is corupted or in the wrong spot.
Old Jan 18, 2007 | 08:31 PM
fast98's Avatar
i'm a tech at a dealer, i already tried that. its just weird the stock tune is just fine. i'll post up the hpt file when i get a chance.
Old Jan 18, 2007 | 08:37 PM
fast98's Avatar
well i cant upload a .hpt due to the fact that its 2.14mb and the limit is 2.00mb someone let me know another way please.
Old Jan 18, 2007 | 09:16 PM
Poke around through the file with your editing software and see if anything looks goofy IE bizare table values for spark like 255. Could be a bad read. What exactly did you change ?
Old Jan 18, 2007 | 09:38 PM
foff667's Avatar
LS1TECH Sponsor
you could always make a separate post on our forum & just post the link here...our forum accepts the larger files up to 4mb last I checked.
Old Jan 18, 2007 | 10:48 PM
rgvsierra's Avatar
i've come across that problem on a 07silverado new body style, where it will become un responsive to throttle changes.
