Map sensor bad? Reading high at idle
Old Jan 20, 2007 | 04:55 PM
bluehawk2's Avatar
Default Map sensor bad? Reading high at idle
My friend has been helping me tune my car and we noticed a problem with the map sensor. The map sensor is saying that i am running 55-60 kpa at idle. Then when I drive down the road it drops to around 40-45. Is my map sensor going bad or is there some other explanation for this?
Thanks
Old Jan 20, 2007 | 09:05 PM
bluehawk2's Avatar
hmmmmmmmmmmm stumped me too
Old Jan 20, 2007 | 10:11 PM
2xLS1's Avatar
Those are normal MAP values for those conditions.
Old Jan 20, 2007 | 10:55 PM
txhorns281's Avatar
Thanks
Cam = reduced idle vaccuum = increased idle MAP
Old Jan 20, 2007 | 11:02 PM
bluehawk2's Avatar
Thanks, that's one less problem for me to worry about.
Old Jan 20, 2007 | 11:18 PM
bluehawk2's Avatar
So, when i get out on the road an increase vacuum the map sensor reads less. map an vacuum are inversly related?
Old Jan 20, 2007 | 11:26 PM
2xLS1's Avatar
Depends on the units you are reading MAP in.
High kPa = Low in Hg
Low kPa = High in Hg
Old Jan 21, 2007 | 09:13 AM
ChrisS@sdpc's Avatar
This is one place were metric units are really nice. ~100kPa is atmospheric (standard) but your specific atmospheric condition is affected greatly by your elevation. 100kPa is sea level, but in Denver you may only see 85kPa.
If MAP reads
0 - 100kPa = vacuum
> 100kPa = boost
Or you can substitute in your kPa value for your specific atmospheric conditions above. No more 10inHg of vacuum here, 7psi there, etc.
Old Jan 21, 2007 | 09:21 AM
jimmyblue's Avatar
Moderator
Cams depress vacuum / raise MAP especially at lower RPM,
at cruise you are up in RPM and the available overlap-time
that makes for vacuum loss (drawing from both intake and
exhaust, whichever is "cheaper" for pressure) is cut back.
Vacuum =(BARO-MAP) in PCM-world.
Old Jan 21, 2007 | 01:37 PM
bluehawk2's Avatar
Thanks, it's making better sense to me now. I really don't know a lot about tuning at all, so thanks for explaining.
