Interesting Read
http://www.monodax.com/forums/tunerc...ning-help.html
I thought the most interesting comment was 'Widebands don't work in closed loop' comment.
I can't speak for onboards because mine is onboard open loop, but for the countless hours that I have spent on a dyno with a car I can say that the great majority of cars running closed loop you can stick a sniffer in the exhaust and get 14.7 for most steady state operation...... seems pretty close to me.
Most of the internet tooners equipment is not going to pick up this kind of variance.
Ryan
About the only point I saw that I would consider to be a valid concern would be buying a used car that had been tuned in SD that now needed to be smogged. If I ever sold my car, I'd put my narrowband O2 sensors back in as well as the MAF sensor just to save on the grief. Then THEY could replace the narrowbands every year when they die (probably sooner), and have fun with their K&N air filter (that people will inevitably put in because of their marketing hype) getting oil spatter all over the wires.
While the PCM was never designed to be used the way I do, it most certainly works, and works quite well (open loop, SD). Considering I'm an enthusiast, I don't mind spending some extra time tweaking my tune every now and again to keep it running its best.
Yes, I could jig-rig the VE for idle, distort the IFR table, and get the desired AFR in probably 1/10th the time it would take me to do it the other way. But, I like having my WBO2 AFR match the PCM commanded AFR (again, within +/- 2%). I choose to run open-loop because (as stated above) I don't want the anual expense of replacing NBO2's. I like the MAF and don't fall into the full-time SD hype - especially with the weather changes we see here in Michigan.
As for the whole PCM debate...I'm typing this message on-site at a major OEM right now and deal with some of the people that buy & engineer the ECM's in all of their vehicles. I have yet to hear about design complaints. The bigger complaint is cost, how it can be done for less, and who's technically qualified to do it....just like any company producing any product.
In the end, I don't know what my tune will look like. But, I know the AFR's will be where I want them, the spark will be where it's making some good power without detonation, and I WILL be happy with it. And the best part is I will know that I acheived my goal of tuning my car on my own based on what I've managed to learn over the past year and a half tinkering with my copy of EFI Live.
I'm a tuning newbie, and that's not a hard concept for me to grasp.
