Cluster question
Old Jan 27, 2007 | 04:57 PM
FBGSU02's Avatar
Default Cluster question
my "air bag" light is on is there any way to reset it or turn it off?
Old Jan 27, 2007 | 05:39 PM
horist's Avatar
air bag light will go on if there's a failure somewhere that's detected... it should be setting a code if the car's scanned...
No way that I'm aware of to turn the light off (I would imagine disconecting the battery for a while could reset it, but if it's a real fault being detected, it'll just come back) ... any scanner that can also scan the BCM should be able to pickup the airbag code
Old Jan 27, 2007 | 07:27 PM
Doc's Avatar
Doc
more info...mods, circumstances of the light. Won't go away, will go away? Plent-O-Senarios. Enlighten us further.
Old Jan 27, 2007 | 07:40 PM
2001NBMZ28's Avatar
Wouldn't want to even try and turn it off if it comes back - this is one of the very, very rare instances where I'd bring it to a dealer.
Old Jan 28, 2007 | 11:20 PM
FBGSU02's Avatar
ok when a car is wrecked and the air bag deploys the air bag light will illuminate right? well mine was wrecked, now fixed and have a light. so should i disconnect the battery? i have had it scanned and nothing came up. i even put in a different cluster in there and no light came on so could it be a malfunction in the light itself? or should i try to reset the whole dang thing. b/c thats one thing that hasent been done.
Old Jan 28, 2007 | 11:46 PM
warp_6's Avatar
I'm not sure how GM does it?I work on Inifiniti's. If a bag has been deployed the sensor that caused the deployment has to be replaced as well as the diagnostic unit (Air Bag Computer). The diagnostic unit has a sensor in it aswell. Codes and lights can't be turned off or erased with out our hand held computer (consult). I'd take it to the dealer.Good luck.
Old Jan 29, 2007 | 09:57 AM
FBGSU02's Avatar
ok the sensor was replaced b/c the bags are back in. i think im going to pull the battery cable and let it set for an hour thats what the dealer told me to do. they said if that didnt work bing it to them. "will pulling the cable mess up my tune?"
Old Jan 29, 2007 | 12:21 PM
Doc's Avatar
Doc
No, the tune is written into the PCM. Any fuel /idle trim information will be lost but the car will learn again. That is if your tuner left those funcitons turned on.
Old Jan 29, 2007 | 12:43 PM
Kage's Avatar
Cool
I had the same problem when i replaced my orig. gauge cluster with the 01 yr. one. It threw an "AIR BAG" light on.....
You have to have the new air bag married to the gauge cluster.....
Take it to any good auto repair shop or GM dealership.
It takes like 5 min. with a special edit tool, i forgot the proper term for it, to fix the problem......
Shouldn't be more then $40.........
Old Jan 29, 2007 | 01:23 PM
FBGSU02's Avatar
ok so i can go to any local shop and they will have the tool? i have an OBD2 scanner machine will that work?
Old Jan 29, 2007 | 07:04 PM
FBGSU02's Avatar
ok guys i got a guy i know who is going to do it. but i am wondering can he just reset my light only. or will it reset my whole comp. b/c i have a tune for my cam on it?
Old Jan 29, 2007 | 07:12 PM
slow's Avatar
does it require a tech 2?
I did something similar to a freind when he swapped clusters into his car, and needed something to sync the cluster to the airbag module using a tech 2 on a 2002 car.
Ryan
Old Jan 30, 2007 | 09:49 AM
FBGSU02's Avatar
not sure the guy is a friend of the family, he works for a highly reputated body shop here in savannah. he said he can get the machine that they use. but i want to make sure it wont affect my tune for my cam.
