Help! SES P1614
Old Jan 30, 2007 | 12:20 PM
02SS#406's Avatar
Default Help! SES P1614
Driving along yesterday, and the SES light pops on. Go to Autozone and hook up the OBII scanner. It pulls this code, P1614, and is "Loss of RIM serial data". Any ideas? Part of the AIR system, I guess. I've searched a LOT, to no avail.
Old Jan 30, 2007 | 01:17 PM
06MonteSS's Avatar
LS1Tech Sponsor
ehh, I got nothin' either... interesting...
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old Jan 30, 2007 | 02:01 PM
02SS#406's Avatar
Gotta be a GM tech or two on here that have seen this. Pleeeease!
Old Jan 30, 2007 | 02:47 PM
2001NBMZ28's Avatar
Don't see that code in my helms, obdii.com says it for a "9" engine on their site. Sure it wasn't P1416? It's a lot more common and usually just a gunked up passenger side AIR check valve.
Old Jan 30, 2007 | 04:14 PM
02SS#406's Avatar
Where is that check valve located?
Old Jan 30, 2007 | 04:55 PM
2001NBMZ28's Avatar
Double check the code first - the passenger side air check valve is in between the metal air pipe coming off the header, then connects to the air hose - it's the black disc shaped valve right above the #4 cyl coil pack. If that's it - easy to replace yourself, GM PN is 12565503 but available at your local parts store and not expensive.
Old Jan 30, 2007 | 05:09 PM
02SS#406's Avatar
I'll get it re-scanned at the Zone tonight. It's popssible the guy flipped the code #'s. Thanks for all the help, especially giving me the location of the check valve!
Old Jan 30, 2007 | 08:31 PM
02SS#406's Avatar
Sure enough, code is P1416. Thanks, again guys...it's what makes this website great!
Old Jan 30, 2007 | 08:53 PM
2001NBMZ28's Avatar
Thought that might be the case - after replacement light should go off by itself after a few cold starts, but will stay in history for 40 cycles, unless you reset it. Auto Zone is great for reading codes for free - but always watch over their shoulder and write them down yourself.
Old Jan 30, 2007 | 09:21 PM
02SS#406's Avatar
Yeah. I keep telling myself I need to just bite the bullet, and by a scanner for the house. This may be what convinces me to do so. Thanks again!
Old Jan 30, 2007 | 09:42 PM
2001NBMZ28's Avatar
If all you want is a cheap obdII code reader check out harbor freight.
Old Jan 30, 2007 | 10:46 PM
horist's Avatar
^^^ I don't know this for sure as I've never used a cheap non GM OBDII scanner... but P0 codes are the ones that the government mandates must be released to everyone
P1 codes are manufacturer specific (at least that's my understanding... again I may be wrong)
cheapie code scanners may not be able to read the P1 codes (and likely won't be able to read B/C etc... codes)
Old Jan 31, 2007 | 06:22 AM
02SS#406's Avatar
I think you are correct on this. That's the reason I haven't bought one. The good ones are a litttle pricey, but I'm looking for one as we speak, via internet.
