Anyone had this issue?
Old Feb 12, 2007 | 04:14 PM
AzzHauler's Avatar
From: Richmond, VA Where fast cars, well......are hard to come by.
Default Anyone had this issue?
Stock 01 auto c5. PCM tables appear stock, though the OS number matches a 2003 on efilive's site (flash at a dealer maybe?). Anywho, stock timing tables + 93 octane = audible knock like a ***** in church. Take 4 degrees out of the high table, audible knock goes away and reported KR drops to about 3 degrees or so (from 6-7).
I suppose once it warms up a tad I'll have to start with looking at fixing the pcv system.
Old Feb 12, 2007 | 08:12 PM
Frost's Avatar
lean fueling invites knock...
Old Feb 13, 2007 | 12:47 PM
AzzHauler's Avatar
Thank you captain obvious. It was richish, lower 12.x on the 2nd pull. 3rd pull was actually a tad leaner, while picking up power AND less kr.
Now answer my other question in your thread!
Old Feb 13, 2007 | 02:10 PM
pdanrichey's Avatar
clogged fuel filter...fuel pump not working right, etc etc...?
Remember, lean fueling invites knock...I want to be a captain also
Old Feb 13, 2007 | 02:13 PM
Frost's Avatar
What?
TO ANYONE ELSE READING.... just wanna say....
I don't know this guy
What's it look like pulling the TB, look like it's been eating oil?
SSpdDmon's Avatar
Download a stock tune and compare timing tables. What may appear stock for one year can be very aggressive for another (ie '99 vs '01).
If there doesn't seem to be a problem there, then chances are your problem is not in the tune - especially with a stock timing table on a stock or nearly stock car.
Old Feb 13, 2007 | 02:14 PM
GMfan's Avatar
Carbon buildup in the combustion chambers and valves??
Run some seafoam through the brake booster line with the engine running to clean it out.
Old Feb 14, 2007 | 11:28 AM
AzzHauler's Avatar
Probably gonna do the seafoam when the oil change is here (any day now...). The stock timing on it only peaked around 26, and 22 is about the max in the high table now. I looked at some other files, but can't recall atm their numbers. Sucks that I can't open 2 different OS calibration files in efilive for comparison in the same program instance.
My question was about where you got the iat weatherpak connecturs, Uncle Teddy.
Old Feb 14, 2007 | 12:09 PM
12secSS's Avatar
Just because it is pulling 4 degrees of knock during WOT, it doesn't mean that is all the timing you need to reduce for knock to go away. Some calibrations have a set 4 degrees of timing to retard under certain condition, like WOT. So if you lower the timing by 4 degrees, say from 26 to 22, and still get knock ... if you still see 4 degrees, you may want to be more agressive on reducing timing because knock retard has been maxed out and it will not pull more timing. This could damage you engine. If you see less then 4 degrees of timing retard, then you are getting closer to a better timing curve. JFYI.
Old Feb 14, 2007 | 12:33 PM
Frost's Avatar
12secSS is right; in PE only 4 degrees can be pulled. You don't have any knock sensor codes do you? No one went in and turned them off either did they?
I don't know uncle Teddy, but I am buying the connectors in Bulk from Weatherpack already pig-tailed so that I don't have to deal with pins and crimping them.
Old Feb 14, 2007 | 03:37 PM
AzzHauler's Avatar
Hmmm. Well it was pulling well more than 4* before the table changes. It wasn't a case of not pulling knock, or pulling a constant 4* as when there is a sensor failure. I was more or less initially posting just ranting about it pinging quite excessively all stock, which reducing timing helped fix (imagine that). I still get up to ~3* now which puts my effective timing at 18-19ish. For the moment I'm just glad it's not so bad that I can hear it anymore... But I'll get around to not being lazy and fix it soonish. But you shouldn't really have to fix a stock car...
Old Feb 14, 2007 | 03:52 PM
12secSS's Avatar
Could be running lean, have you log the AFR with a wideband?
Old Feb 14, 2007 | 04:04 PM
AzzHauler's Avatar
The wideband was used on the dyno. The worst pull (as far as knock) was in the lower 12.x:1. The next pull was leaned out a couple points and had less knock. Never was leaner than 12.5:1.
