need a little help!
Old Mar 1, 2007 | 11:22 AM
dreamls1's Avatar
Default need a little help!
I am putting in a 02 Ls1 with an 02 Pcm, Will a 98 Harness both incar and engine work for this PCM or will i have to get a 02 harness.
Old Mar 1, 2007 | 11:59 AM
dreamls1's Avatar
anyone?
Old Mar 1, 2007 | 12:08 PM
2xLS1's Avatar
With a 02 PCM you will need a 02 harness, unless you want to repin almost every pin in the 98 harness connectors, then there will still be some issues. It would also help to know what MY vehicke you are putting the 02 engine and PCM in.
Old Mar 1, 2007 | 12:34 PM
dreamls1's Avatar
I am puting it in a trans am.
Old Mar 1, 2007 | 01:29 PM
2xLS1's Avatar
That helps a lot.
Old Mar 2, 2007 | 10:15 AM
pewter01z's Avatar
I think the 98 body harness will work, as long as you use the 99-02 engine harness. Someone can correct me if I'm wrong.
Old Mar 2, 2007 | 05:38 PM
94SS's Avatar
I have seen a automatic transmission destroyed in this situation the sensors,harness and computer were not the same. Maybe check with Speartech or painless wiring.
Old Mar 3, 2007 | 03:54 PM
dreamls1's Avatar
yes i was going to use a 02 engine harness but i need to know if a 98 body will work
