P0174
Old Mar 6, 2007 | 05:09 PM
dameter21's Avatar
Default P0174
Fuel system for bank 2 was too lean. Any ideas, I just bought another MAF it'll be here FRI, any other things it might be???
Old Mar 6, 2007 | 05:15 PM
2xLS1's Avatar
If it was the MAF, it would probably set both bank lean codes, not just bank 2. You need to hook up a scanner and see what the Ltrims are and what the O2s are doing. Providing a lot more info on the car always helps too.
Old Mar 6, 2007 | 06:34 PM
dameter21's Avatar
do you think it could be a bad 02 sensor on the right side.. wouldn't that have it's own code though.
Old Mar 6, 2007 | 06:47 PM
rkinney's Avatar
It could be a number of things. On all the trucks, the intake gaskets are bad about leaking and setting p0171 and p0174. There's a reviesd gasket for those. I have seen them set just a code for one bank only. I have only seen these codes once on a vette due the gaskets, but never on a f-body.
Old Mar 6, 2007 | 07:05 PM
dameter21's Avatar
well I don't have a techII or any scanner at that , how much does it usually cost just to find out whats wrong with it at the GM dealership.
Old Mar 6, 2007 | 07:10 PM
rkinney's Avatar
Depeneds. At the dealership I work at, it is usually .5 hr for diagnosis which is like $42.00.
Old Mar 6, 2007 | 07:14 PM
dameter21's Avatar
well I guess I'll just take it in and find out what's wrong, and then take it home and fix it...I know you guys must just hate that..take the time to bring it in check it out and not get any more tenths to fix it...but hey I'm broke...
Old Mar 6, 2007 | 07:47 PM
rkinney's Avatar
I understand man. You could try and spray the pass. side at the base of the intake with carb cleaner or propane(if available) and see if the engine picks it up.
Old Mar 6, 2007 | 09:22 PM
dameter21's Avatar
good idea I'll give it a try..
Old Mar 10, 2007 | 12:01 PM
dameter21's Avatar
ha found the problem pinced egr seal, cost 12 bucks insatlled in 3 minuites..
