Need some help with hesitation during acceleration
Background: Custom tuned (by me) LS1 with supercharger. Normally runs fine, but started to get an intermittent problem.
Problem: In closed loop operation, sometimes, it will hesitate really bad (to the point of almost dying) when I accelerate normally from a stop. Almost feels like it's running out of gas.
I can force it into open loop, and it runs fine. It hasn't done this when I have the scanner connected, being that the problem is intermittant.
Question: Besides ignoring the O2s, are there any major things happening in open loop vs. closed loop that I'm missing?
BTW, for grins I disconnected the MAF to force it to run in SD mode and the problem was still there.
Right now I'm trying to pinpoint the differences between Open and Closed loop. I can definately make the problem go away by forcing Open loop.
By determining the differences, I can begin the process of elimination. For example, if timing isn't changed between Open/Closed loop, I can eliminate it. VE/air tables, the same.
go together.
When you are accelerating, at the point of the problem, what is
your MAP? What commanded EQ results from this in open loop,
perhaps fatter than the 1.000 closed loop target and covering
up an excess advance?
If closed loop is your normal intention for this load-point then
reducing spark would be the ticket. If you want acceleration
there and enrichment then you might just want to bring PE
in earlier. Or shift into a better engine RPM.
I'd settle down the KR attack/decay so you can see better
the real ping-hits without the long lazy tail, log the KR, EQ,
MAP, RPM, TPS and Dynamic Cylinder Air and the delivered
advance. This should let you decide which (fuel or spark)
is out of line.
Another thing that might bug closed loop is the proportional
fuel stuff, it swings rich and lean continuously but if it is
let swing too far, it may bury itself into ping-inducing lean
territory and saddle you with KR even though the average
fueling is right. See if KR follows a bottoming NBO2 cycle
in the waveform, if the waveform is lazy and squared off
then consider reducing the prop fuel amount for that airflow
(and neighbors). You want an edgy sawtooth, not a falling
down drunk looking O2 waveform, keeping you tighter to
center. Long tubes mess this up. It may or may not be an
actor here, just something to look at if nothing else looks
like the problem.
like the problem.
The proportional fueling reduction... does it help the issue with some of the really bad long tubes? The stainless seem to do it worse; I'm figure the heat loss plays a large factor.
