SLP Predator custom tune question?
Old Mar 9, 2007 | 08:46 AM
Z28XTC's Avatar
Default SLP Predator custom tune question?
When I first bought my Z28 I got one of the SLP Diablo Predators and found with a lid and a Loud Mouth the SLP custom tune that is put in this predators gave me little or no gains so I returned it to stock tune and only really used it for setting my axle ratio's etc. Now this custom tune is meant to be worked out on a dyno to give your car maxium gains with the SLP performance pac according to there comerical.
So since I returned my car to stock tune six months or more has past and I have added a SSRA,LS6 manifold,march pulley,1 7/8 kooks headers,ORY,got rid of the loud mouth and got a magna flow,level 2 preformer built trans,3.73s,3800 vig stall, aluminium drive shaft,ported maf and done a T/B by pass.Now I realise some of these mods will having nothing to do with the next part and my question but I decided to load in the SLP performance pac tune that is on the predator and wow what a difference I got more TQ and Power of course I dont know how much but could someone chime in and give me an idea it feels like 20hp or so is this possible?
Old Mar 9, 2007 | 09:03 AM
SSpdDmon's Avatar
Only sure fire way to know what's going on is to hop on a dyno. The butt-dyno can be deceiving. Just out of curiosity, where are your LTFT's when cruising around and what O2 mV's do you see at WOT from the B1S1?
Old Mar 9, 2007 | 09:14 AM
Z28XTC's Avatar
You have lost me a little LTFTs? o2 mns from B1S1? I have a rough idea but explain it and I will go for drive with custom tune and stock tune and tell you.
Old Mar 9, 2007 | 09:24 AM
06MonteSS's Avatar
LS1Tech Sponsor
LTFT = long term fuel trims
O2 B1S1 = Oxygen Sensor - Bank 1, Sensor 1 (the pre-cat O2 sensors). You want to see what the millivolts are at when at WOT.
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old Mar 9, 2007 | 09:43 AM
SSpdDmon's Avatar
You should be able to see those in the scanner while driving. Just give it time to adjust between tunes. The LTFT's can take several days of driving to learn everything after your flash in a new tune (stock or custom).
Old Mar 10, 2007 | 03:23 AM
Z28XTC's Avatar
All I can say is my car feels like a whole new beast!
Old Mar 10, 2007 | 07:49 AM
Sneakyws6's Avatar
On the tree
If that Predator has the version1 firmware in it there is a free upgrade for the firm ware from Diablo that will give you alot more parameters and functions to be able to adjust.
Old Mar 10, 2007 | 07:54 AM
EchoMirage's Avatar
from what i understood, the custom tune in the predator was only if you had an aftermarket MAF. doesnt matter what else you had, but if you did only the SLP or another MAF, you needed a custom tune. i dont know what would happen if you used a custom tune on a stock MAF. i doubt it would be overly bad for it though, just wouldnt be up to 100% potential.
Old Mar 12, 2007 | 11:13 AM
Z28XTC's Avatar
Version 1 firmware? How do I tell if its one of those? Is it that true about the maf? If so should I perhaps get one of those??? I thought everyone says they are rubish but in this case are they good for a few more HP when combined with the SLP preadator tune???
Old Mar 12, 2007 | 11:35 AM
Sneakyws6's Avatar
On the tree
I would leave the MAF alone. The mod does not give that much of a return to compensate for the hassle of buying it. The stock MAF is good for up to about 500hp. So unless you are over that amount dont worry about it.
As far the firmware, when you power up the Predator what bios and version does it say on the screen?
Old Mar 12, 2007 | 11:40 AM
stangbangin69's Avatar
Default link????
link to the free update on the predator plz???
Old Mar 12, 2007 | 11:46 AM
Z28XTC's Avatar
Here is what it says on they slp website about the tune.
Looking for the most powerful PCM-tuning tool on the market? Unlike typical off-the-shelf programmers, the DiabloSport II by SLP comes armed with an ultra-hot custom tune developed specifically for your vehicle application. Through extensive testing on our in-house dynamometer, our engineers were able to determine the precise levels of spark and fuel required to achieve optimal horsepower and torque at each rpm increment.
Old Mar 12, 2007 | 11:52 AM
Z28XTC's Avatar
Sneaky Ws6 I do know about the stock maf being good for 500hp but what I am asking is when the slp maf is combined with slp preadator is it good for some more TQ/HP?
Old Mar 12, 2007 | 05:59 PM
Sneakyws6's Avatar
On the tree
Stangbanging69 go to diablosport.com and it is on the site, you have to send the unit in for the firmware update and the stock tune has to be in the car in order to do that.
Z28xtc, what good does the SLP MAF going to do you if you dont really have mods that require it as of yet? I mean if you want to throw the money way then go ahead. I am just saying there is money to be sent elsewhere for more power.
Old Mar 12, 2007 | 08:51 PM
thnx Sneakyws6 will do
