More Tuning Questions!!!!
here is my problem.. i have terrible warm starts. My IAC will not reset to 310. we have tried every god damn thing possible. How do you fix the IAC??
so here is what we tried yesterday. tried the throttle stop screw. we unscrewed it so that more air would get in on start up. Viola.. warm start was fixed. that biatch started right up. But you fix one thing and another thing happens.. My car used to idle at 850 - 870. now it idles at 1000 - 1100 and when driving i have idle hang.
so we turned the screw back down. got my idle back to where it should be, no more idle hang, but know coming to a stop the idle surges. dips down to 400, up to 1000 back down 400 up to 1000 then finally it holds... SO WTF!!!!!!
So i put the screw back up a bit. little better of a warm start, no idle hang and no dipping.. so i am getting pissed now.
HELP!!!!!!!!!!!!!!!
I just got my setup running yesterday and it holds a fine idle with just a few settings changed, lol.thanks for rubbing it in Brad
hey BTW i poted my sound clips in the externa section and multi media section.. take a look
https://ls1tech.com/forums/pcm-diagnostics-tuning/673147-idle-tuning-ls1-edit-sorry-asking-i-searched-though.html
i never did that.. was i supposed to obviously....
yea man that warm start with the coolant is killing me. but when i tuned the idle set screw to opne the TB blade up it started fine.. but then i got idle hang...
I've always done this (and always do) but check this out... On 2 cars now that had cams tossed in that I tuned, the guys jacked the TB screw open to help them out getting the car to me to get it tuned, and in both cases, the TPS had reset itself. Both of them had moved it so far that they had idle hang and massive "cruise control" but the scanner showed 0%TPS when the cars got to me and neither guy did the reset.
Just something I noticed and thought I'd pass along.
right now i think the set screw is fine...
At operating temp 168*, the IAC reads 45 - 65 at idle..
bank 2 is +2 then bank 1 was +8 on the long term fuel trim. So they are off.. I think that my 02s are bad...
i filled up yesterday on 93 octane, drove 75 miles, and i am at a half tank. that was not really going above 3K rpms...
This cam is killing me....
can the cut of 110 be the cause of all my problems.
read my thread in the internal forum man
Go get a cam like mine man
232/236 112 LSA XE lobes FTW!!!! bank 2 is +2 then bank 1 was +8 on the long term fuel trim. So they are off.. I think that my 02s are bad...
I would guess it is better to run wideband sensors to simulate the narrowbands right? I am running kinda rich at idle due to my overlap (10 degrees). Widebands in place of the narrowbands would help to clear this up right?
