Help ID 85mm MAF
Old May 2, 2007 | 02:10 PM
96inSA's Avatar
Default Help to identify an 85mm MAF
Need help in identifying this MAF or more specific the modification that has been made to it. It is a Delphi 25168491 but it has a resistor soldered to it. It also has a 3-wire to 5-wire harness adapter. The screen has been removed. Any help or ideas would be appreciated. Thanks.
Old May 2, 2007 | 05:35 PM
jimmyblue's Avatar
Moderator
It's the same scheme as SLP but the resistor looks different.
SLP does not remove the screen. This might be a Pace "Z06
calibrated for F-bodies" or some such.
Old May 2, 2007 | 05:50 PM
Rob98LS1's Avatar
looks like it flows nicely
Old May 2, 2007 | 06:54 PM
96inSA's Avatar
The maf had a screen at one time but was removed at some point.
I called Pace and described the resistor and was informed that they do not install a resistor on their calibrated mafs.
Can anybody with a SLP maf verify the use of a resistor like this one?
Old May 2, 2007 | 10:47 PM
jimmyblue's Avatar
Moderator
SLP used a 2.7K on the late-years version. I had one, took
it off, substituted various other values etc. Mine had the
2.7K (red/violet/red) 1/8W resistor with a heat-shrink jacket.
People who have Pace MAFs have told me they do have
(or did at the time) a resistor in the same place. I have
to doubt that Pace, SLP or anybody else changes the
potted electronics inside a Delphi MAF.
Old May 3, 2007 | 09:18 AM
wait4me's Avatar
I agree with Jimmy, All of the gm mafs for our cars are just a stock one from another car with that resister to make it so you can run it even though it has a different transfer function than the stock table inside the pcm. If they didnt put in that resister to trick the Computer, then your car would be very wrong in its fueling.
Old May 3, 2007 | 01:17 PM
Datzneat's Avatar
I just picked up a used delphi maf. I'm pretty sure mine didn't have that resistor. I'll double check when I get home.
Old May 3, 2007 | 05:12 PM
the_merv's Avatar
I got one out of a Truck, same thing without a Resistor. I re-wired the Harness to the 5-wire Connector, all the other 2 wires are for is the Temp Sensor. That Resistor looks interesting...
Are you missing one of the Feelers, or did it not show in the pics..
