Predator question?
Old May 15, 2007 | 08:15 AM
jeremy341a's Avatar
Default Predator question?
I used my predator to tune my car. I went to modify factory tune and changed the fan settings, torque mangment settings and shift settings only. I then installed this tune. However when I go to the options menu and look at which tune is installed it says diablo tune. Does that mean I just tuned it with the diablo or did is actually instal the power tune also?
Old May 15, 2007 | 08:20 AM
06MonteSS's Avatar
LS1Tech Sponsor
the power tune IS the Diablo tune.... if you want the diablo tune installed, then select the Diablo tune and choose "modify" instead of install... make your changes as you indicated in your post, then choose to install the tune. This will install the Diablo power tune with your adjustments made to it.
The Factory HP tune is actually a tune designed to allow you to adjust WHATEVER is on the PCM in a GM vehicle, without applying any tuning from the Predator.
so, if you had previously installed the Diablo tune, then made those adjustments via Factory HP tune, then the Diablo tune is still installed, and now with the adjustments you made.
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old May 15, 2007 | 08:37 AM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
And note that you can just go in and edit your factory tune as well, and install it instead of the Predator tune if you wish to do so!
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old May 15, 2007 | 08:43 AM
sprayjunkie's Avatar
I'll have you doing Predator tech support in no time!
Thanks
Mike
Old May 15, 2007 | 08:56 AM
jeremy341a's Avatar
I completely reset the vehicle back to stock. I then went to modify factory tune, modified it and installed it. So I want to verify I do not have the power tune installed. The programmer says diablo tune (I believe). So is the tune stock other than my changes? I ran it with the tune at the track and now I want to try it with the stock tune onther than the changes I listed.
Old May 15, 2007 | 09:25 AM
Thanks
Mike
__________________
Old May 15, 2007 | 09:48 AM
06MonteSS's Avatar
LS1Tech Sponsor
if you restored your original backup correctly, it should show the original backup as the last tune installed. if it is still showing the Diablo tune as the last tune installed, then you didn't do something right.
__________________
Old May 15, 2007 | 10:08 AM
If you are trying to mod the factory tune, last tune written should read 'factory hp tune'.
If it says 'diablo tune', then that is what is on the PCM.
Old May 15, 2007 | 10:52 AM
jeremy341a's Avatar
Once I restored the factory tune, it did show the orginal as the last one installed. I then modified the factory tune and installed it. Now it shows predator tune. Shouldn't it say something else.
Old May 15, 2007 | 11:35 AM
So you restored the factory tune, then went in to "tune it" and selected the factory tune to modify...made your changes to it, and escaped out until it began to flash that tune in??
__________________
Old May 15, 2007 | 11:36 AM
jeremy341a's Avatar
Ok just redid the whole thing. Reset the car back to stock. Predator verifys stock tune. Then went and modified the stock tune installed it and predator now says predator tune installed. I thought it should say stock hp tune installed or is it different on my model predator. It is for a 99 camaro and was just updated by diablosport a few months ago.
