Code P0106 question
Old Jun 6, 2007 | 12:14 PM
ExceSSive's Avatar
Default Code P0106 question
I got this code a long time ago when my intake was missing a bolt. I replaced the bolt and no problems.
Now a friend is having the same code but he is not missing a bolt and they are all tight. So, what else can cause this code?
Old Jun 11, 2007 | 09:40 AM
ExceSSive's Avatar
Nobody has an idea???
Old Jun 11, 2007 | 02:30 PM
koolrayz's Avatar
big cam
Old Jun 11, 2007 | 10:23 PM
Shallow Bay's Avatar
http://www.gearchatter.com/viewtopic9390.php
Old Jun 13, 2007 | 07:28 AM
ExceSSive's Avatar
Originally Posted by koolrayz
big cam
Will a big cam just cause this code to go off randomly?
Old Jun 13, 2007 | 07:54 AM
Silverhawk_02TA's Avatar
Any cam with significant intake port reversion, which causes the MAP to jump all over the place at idle/off idle, can set this code. My Torquer does this. You can adjust the MAP thresholds for setting the code, or if you're lazy like me you can just kill it entirely.
Old Jun 13, 2007 | 09:24 PM
one2run's Avatar
thanks guys... we just turned the mil off, and look ma, no light! changed the range as well, but it kept popping the code.
Old Jan 7, 2009 | 02:28 AM
HardyHar's Avatar
Sorry to bring this back, but I believe my Torquer v2 is causing my p0106 problems. Is the V2 (232/234 .595/.598) a large enough cam to do this? What are the specs on the V1? I've been over the car 3-4 times and can't find a leak anywhere.
Thanks!!
Old Jan 7, 2009 | 07:05 AM
koolrayz's Avatar
I had two freinds with cams in that range on 346 ci motors that had the issue. Change the parimeters and call it a day. That way it wont trip the code
