3 Bar Issues
Old Jun 27, 2007 | 10:39 AM
chrisn203's Avatar
Default 3 Bar Issues
I did a search on this problem and tried everything i found but still does not work. I have a 408 tt vette and when i got up to about 14 psi i get reduced engine power. At 12.5 psi it was fine. I have tried everything i can think of to shut rep off but nothing works. Can anyone tell me how to disabe rep. If so it would be greatly appreciated. Thanks.
p.s. using hp tuners.
Old Jun 27, 2007 | 11:45 AM
foff667's Avatar
LS1TECH Sponsor
what codes are you getting? if its p1514 generally you just need to raise that tables limits so your not breaking it.
Old Jun 27, 2007 | 11:51 AM
chrisn203's Avatar
I have the table maxed at 4.10 already
Old Jun 27, 2007 | 12:11 PM
LS1curious's Avatar
REP ????
Old Jun 27, 2007 | 12:17 PM
chrisn203's Avatar
reduced engine power (rep) code is p1514 even with table maxed
Old Jun 27, 2007 | 12:21 PM
chrisn203's Avatar
ps it also does it at exactly the same rpm and kpa right around 4100 and 197kpa.
Old Jun 27, 2007 | 12:22 PM
LS1curious's Avatar
have you tried incearsing the table for Airflow error vs KPA. There is a diagnostic table for just that. its a 2d table.
Old Jun 27, 2007 | 12:25 PM
chrisn203's Avatar
i dont see that table. where exactly is it
Old Jun 27, 2007 | 12:28 PM
qqwqeqwrqwqtq's Avatar
Scale down your IFR table and VE table by the same percentage (so fueling remains correct) and you should be good.
If the VE values on a vette are too high you will go into reduced power mode.
Old Jun 27, 2007 | 12:30 PM
chrisn203's Avatar
this might sound dumb but what does ifr stand for
Old Jun 27, 2007 | 12:34 PM
LS1curious's Avatar
Yeah but there is a way around the error reporting.
LS1curious's Avatar
PM me for my email addy. I wanna look at the file.
Old Jun 27, 2007 | 12:35 PM
chrisn203's Avatar
hp tuners
Old Jun 27, 2007 | 12:57 PM
injector flow rate
Old Jun 27, 2007 | 12:58 PM
I've only had success with the way I described.
Old Jun 27, 2007 | 01:21 PM
foff667's Avatar
LS1TECH Sponsor
What year vette? Care to post the file?
Old Jun 27, 2007 | 01:25 PM
LS1curious's Avatar
there is more then one way to skin a cat.
Old Jun 27, 2007 | 01:30 PM
chrisn203's Avatar
01 z06
File Type: hpt
Old Jun 27, 2007 | 01:57 PM
Not disagreeing, just stating my personal experience.
foff667's Avatar
LS1TECH Sponsor
any reason your trying to keep your maf active with an operating system that is meant for Speed Density mode only?
