Real-time tuning for 98' LS1?
Old Aug 10, 2007 | 04:32 AM
Doc's Avatar
Doc
Originally Posted by Runn
Link?
http://forum.efilive.com/showthread.php?t=4964
Old Aug 10, 2007 | 05:22 AM
Vetal's Avatar
That is only about harness swap, or am i wrong?
Old Aug 10, 2007 | 07:21 AM
Doc's Avatar
Doc
http://forum.efilive.com/showthread.php?t=4621
This thread is about segment swapping for the trans segment. The same principle applies, only in your case you would swap the fuel segment.
Old Aug 10, 2007 | 10:05 AM
Vetal's Avatar
"segment" means dashboard (instrument cluster), or block of data in PCM image?
Old Aug 10, 2007 | 10:21 AM
Doc's Avatar
Doc
The main calibration or "tune" is made up of segments, for example, Fuel, transmission, engine mgmt, etc. With EFI Live, you the end user, can swap segments from like Operating Systems. Thus, if you wish to swap a 4L80E into your F or Y body you could swap the segments from a Silverado that runs the same operating system (but obvisouly has a different OS) to control the transmission.
I don't know of any other tuning suite that gives you the power to do that.
In your case from the first EFI Live forum thread I cited if your desire is to upgrade your 98 Fbody to a newer pcm then you could use a 02 Express Van's fuel segment (same OS's) and get your fuel gage to work without swapping the cluster.
Old Aug 10, 2007 | 10:30 AM
Vetal's Avatar
So, all that I need is newer PCM itself, rewire it's connector, replace piece of data in PCM image, and that's all??
Old Aug 10, 2007 | 11:02 AM
Dennis93TA's Avatar
I want to do the same thing. But i'm waiting for a step-by-step instruction so i don't screw anything up
Old Aug 10, 2007 | 01:07 PM
Doc's Avatar
Doc
Yes. With EFI Live.
Old Aug 10, 2007 | 01:46 PM
Vetal's Avatar
Thanx a lot!
What about HP Tuners? Can someone tell what is needed to use it's real-time tuning?
Old Aug 12, 2007 | 05:56 PM
Vetal's Avatar
Anyone can tell me what is needed to make HP Tuners work?
Old Aug 12, 2007 | 06:51 PM
Eurospec2's Avatar
Thanx a lot!
you cannot do this swap with HP Tuners, it wont work
Old Aug 21, 2007 | 07:33 PM
  #32
Vetal's Avatar
No one has done the 98' PCM swap + HP Tuners, or read about it?
Old Aug 21, 2007 | 07:35 PM
  #33
Vetal's Avatar
Originally Posted by Doc
Yes. With EFI Live.
And will I have to buy $600 RoadRunner then, or real-time tuning would be possible with just EFI Live?
Old Aug 21, 2007 | 07:44 PM
  #34
NC98Z's Avatar
Can you still make it thru emissions test. I mean hook up to the port and pass?
Old Aug 21, 2007 | 08:46 PM
  #35
Doc's Avatar
Doc
EFI Live's scantool (alone no RR) has a bidirectional control panel for LS1's that can make temporary (while the car is runing) changes to commanded fuel, spark, etc. that are good tools for making idle and other adjustments easy. Run the scantool, see what the car likes, shutdown, then make the changes.
You get what you pay for when you buy a Road Runner that has a seperate emulator card controlling the GM pcm. Anything can be changed at anytime. There is nothing like it for GM LS1's. Yes, you have to buy a piece of hardware and yes you have to take the time to install it prior to use. You can load any supported GM OS/calibration including FREE Custom Operating Systems to it without having to buy any other licenses other than the one you buy for it-one time deal. Note, I am not hiding the fact that once you finish a tune and save it to your laptop if you want to load it to a stock pcm you will have to license it.
This is a completely different approach than using "unused" pcm memory to perform a limited amount of changes on the stock pcm it'self. This is a less expensive way of doing things however, every "new" vehicle you approach to tune, you need more credits up front.
I believe the standard HP Tuners response for the 98 swap is they have a custom OS for it that you cannot do realtime changes to at all because of the really limited memory on the 98 pcm it'self.
My question is can you run/control a 4L80e with the HPT custom 98 OS. I am not trying to be an *** about this I just think that an individual that is serious enough to run a custom 98 OS could be in the market for a 4L80e.
Think of it this way, the last killer video game you bought...did you even bother with the idea of just running the minimum system requirements?
Old Aug 22, 2007 | 06:17 AM
  #36
Eurospec2's Avatar
Here you go!
This is a writeup i did on my PCM swap on my Corvette, the basic principles of the swap on a F-Body is the same as the vette, just the PCM is in a different location so hopefully this will give you an idea with pictures of what needs to be done.
As Doc posted above me, you will need EFI Live to do this, and youll need a tuner strong in the ways of the EFI, i was lucky enough to have Doc himself tune my car and spearhead the completion of this swap.
Heres the link, i hope it helps, if you have any questions at all feel free to PM me and ill try to help.
Computer swap
Old Aug 22, 2007 | 06:39 AM
  #37
Vetal's Avatar
I still can't see why HP Tuners can work with 99' PCM in 99' car, and can't work with it in 98' car. While EFI Live can do this. Maybe some of HPT people could explain that?
Old Aug 22, 2007 | 07:10 AM
  #38
Eurospec2's Avatar
Although i am not too familiar with HP, i can explain part of it.
One of the things you have to do to make this work is swap in that fuel segment from an 02 express van into your new OS, HP Tuners is not capable of performing this swap.
The other HP roadblock is apparantly when you input a 97 or 98 vin into the tune HP will automatically will write 97-98 cal tables into the tune, wich obviously is not what you want to do, and from what i understand there is no way around this. With EFI Live you can input any VIN and you still have full control of what cal tables you use.
Old Aug 22, 2007 | 08:04 AM
  #39
Eurospec2's Avatar
Originally Posted by foff667
So yes you will be able to swap in a 99+ pcm into your 97/98 vehicle but that pcm would need to have a valid Vin for the Operating system in that pcm.
I dont understand this maybe you can clear it up for me,
Your saying a valid vin for the OS you are using, a 97-98 vin would not be valid for an 02 OS would it, so how would this work? Or am i misunderstanding?
As far as the segment swap, i havent been able to find a 02 express van cal in HP format, does one exist so this could be performed. And your saying that the big guy in the sky at HP can swap these segments, but the end HP user (tuner) cannot right, becouse i happen to know some people (IE Shop owners) have called HP about swapping segments for them and they were turned away saying they do not do this, this was for fuel segment swapping, and swapping trans segments for 4L80E retrofits.
Old Aug 22, 2007 | 08:24 AM
  #40
Vetal's Avatar
foff667, could you please explain it simplier, what do I need if I want real-time tuning with HPT, except rewiring 99+ PCM?
