Why is Tuning a Torquer 2 so difficult or unfriendly?
Thanks for your Opinions guys
What cam are you running now?
Mine ran Ok untuned, I just turned the setscrew on the TB a little to help it idle better before I tuned it.
Alot of tuners, even "pro" tuners patch alot of **** to try and make a big cam run right. I retune about a car a week from a shop near me. Guys got a great rep, but churns out **** constantly.
If they are setup properly, everything seems to fall into place. You end up needing alot less throttle cracker, follower, and some of the other "tweaks" that some guys use to make em run right.
Anybody can make em put up numbers. Its the driveability that makes or breaks a tuner.
I think you might be missing the point. They didn't tell me it's hard to tune, like in they can't get it good or right, they don't like to tune it, like it takes a bunchof changes or soemthing. is this possible? Like i know a bunch of big tuners ahve saved tunes, and maybe there saved tune for this cam varies alot between cars. Is this possible?
Those cams are no harder to tune, or make run right, or get the low end driveability good, or near perfect, or however you want to word it, than any other cam with the same overlap, and therefore the same manifold vacuum and reversion characteristics.
