Lean Code Problem
Old Oct 6, 2007 | 02:10 AM
Zero4488's Avatar
Restricted User
Exclamation Lean Code Problem
Alright...I've been gettting this code since this past March, and I've done practially everything that everyone has told me to try....and still nothing...I'm at my end...any last ideas before I blow the $500 on a dyno tune?
Old Oct 7, 2007 | 10:34 AM
Zero4488's Avatar
Restricted User
BUMP
I need help....please I need ideas...
Old Oct 7, 2007 | 10:10 PM
Zero4488's Avatar
Restricted User
BUMP
I need help!!!
Old Oct 7, 2007 | 10:24 PM
ba78ta's Avatar
which code is it? what have people told you to do?
Old Oct 8, 2007 | 09:47 AM
Zero4488's Avatar
Restricted User
p0171 p0174 Lean Bank 1 & 2. I've been told to clean my MAF, check for vacuum leaks, change my O2's, clean the intake element, run the stock MAF and tune, change the fuel filter, check my injectors, check my fuel pressure....and I still have no leads...
Old Oct 8, 2007 | 10:46 AM
Frost's Avatar
so what was your fuel pressure? For it to be lean on both sides it's likely not sticking injectors, as that woulds require one on each side to stick.... probably a fuel pressure problem.... fresh O2s in the car as well?
Old Oct 8, 2007 | 11:44 AM
Zero4488's Avatar
Restricted User
Fresh O2's....my friend pluged into my car with EFI live...he said my fuel pressure was good and my injectors were working fine....so idk...I've been dealing with this problem since March...and I need to fix it.....
Old Oct 8, 2007 | 12:10 PM
Billiumss's Avatar
What mods did you do to the car?
Old Oct 8, 2007 | 12:16 PM
Frost's Avatar
You can't check FP like that... you have to actually check it, and do it at the rail.
Old Oct 8, 2007 | 12:41 PM
Zero4488's Avatar
Restricted User
SLP LT's, SLP LM1, SLP Lid and Intake Kit, Granatelli MAF, Diablo Sport Tune, AIR Delete....thats about it...and as for the FP...I'll get on checking that...what is ideal FP on a stock motor???
Old Oct 8, 2007 | 12:52 PM
Billiumss's Avatar
You should have about 58 psi for your fuel pressure.
From the look of your mods, you need to get tuned.
Just a FYI - The stock MAF is good for up to 450-500 RWHP.
Old Oct 8, 2007 | 05:22 PM
Zero4488's Avatar
Restricted User
Well as soon as I get a gauge to check it I will....and I'll let you know....what is the lowest it could be safely before causing some serious problems???
Old Oct 11, 2007 | 09:55 PM
Zero4488's Avatar
Restricted User
BUMP
I attached the data log that my friend took the other day...Maybe some one can figure it out....
File Type: efi
Old Oct 11, 2007 | 10:22 PM
SSsuperdave's Avatar
just my $.02. I had the same code on bank 1 after I put duals on. I thought it was a tuning prob, had my tuner flash in different fuel tabels and the code came back after 50 or so miles. Come to find out it was a loose exhaust connection on the driver side collector! f%$king with the O2. I changed O2s also prior to the new tables. Check those clamps. I got the same LTs so I bet that's the prob, I hope.
Old Oct 12, 2007 | 11:52 AM
Zero4488's Avatar
Restricted User
BUMP
Alrighty...I'll check...the only thing is it's on both bank 1 and bank 2....
Old Oct 12, 2007 | 12:04 PM
Frost's Avatar
it takes like 5 minutes to check FP... Not being a dick but you keep bumping this looking for advice but you don't take it.
The only other thing that I know of (cant look at EFIL logs) is I have seen those granatelli MAFs read all over the board. If it were mine I'd throw it in the woods... or at least ebay it.
What did you friend's wideband show at WOT with that thing?
Old Oct 13, 2007 | 11:26 AM
Zero4488's Avatar
Restricted User
BUMP
I'm still trying to get a gauge to check my FP....and I don't remember what the wideband said....and as for the MAF....I tried with with the stock MAF and same old problem...
Old Oct 13, 2007 | 03:29 PM
Zero4488's Avatar
Restricted User
any one that can read efi live files...please take a look at my data log a few posts above...
Old Oct 16, 2007 | 10:25 PM
Zero4488's Avatar
Restricted User
Still no fuel pressure....but tomorrow I'm taking my car to ECS to see if it's something with the tune....I hope it is....
Old Oct 17, 2007 | 12:55 AM
Frost's Avatar
I tuned a car this afternoon that had headers and ORY, slp lid, and slp MAF. At idle, the LTFTs were maxxed at +25 and the STFTs averaged about +6 to +8, and the fuel pressure was good. This MAF deviated from the factory MAF table from 25+% in many places. Yes, it was nice and clean. The car was stupid lean, inital street tuning showed 18:1 at WOT WITH very high LTFTs.
