WIDE BAND O2 KIT??
Old Jun 11, 2003 | 06:29 PM
96SCTA's Avatar
Default WIDE BAND O2 KIT??
Were can I find a kit to build my own wide band O2?? The nearest Dyno is 100miles away. I looked at the FJO(sp) but its like $900, is there any thing out there in the 2-400 range?
Thanks for the help
Old Jun 11, 2003 | 06:39 PM
Vengeance Racing's Avatar
LS1TECH Sponsor
Default Re: WIDE BAND O2 KIT??
You want the good news or bad. You can get a setup for like $500 but it will not record data. I know of a setup that is badass but it is 1200 but will hookup to your laptop and record anything you want and graph. All of this from the cockpit of you car. You would not have a dyno number but you could tune your car perfect with a load and everything. Let me know if you want all the info my local dyno guy was telling me about it and I see him about every three days.
Old Jun 11, 2003 | 07:01 PM
kp's Avatar
kp
http://www.techedge.com.au/vehicle/wbo2/default.htm
Built both the 1.0 and 1.5, work fine and can save some money if you solder. The ver 1.5 works great with a 50.00 palm m105 for logging a/f and rpm. The 2.0 will use a cheaper sensor but isnt out yet. I have always received the kits within two weeks of ordering them, they also offer pre-built units..
Greddy also makes an a/f meter with a seperate O2 sensor, never tried one but it looks pretty decent. I'm not sure what sensor they use, I'm sure someone has tried one by now..
Old Jun 11, 2003 | 07:04 PM
Bink's Avatar
Here- check out Techedges 2.0 .Great price! Version 2.0
joel (Bink)
Old Jun 11, 2003 | 07:42 PM
XLR8NSS's Avatar
Adkoonerstrator
joel (Bink)
It's still not available yet though.
Old Jun 11, 2003 | 08:24 PM
Bink's Avatar
Sould be availble July or August 2003.
joel(Bink)
Old Jun 11, 2003 | 08:35 PM
XLR8NSS's Avatar
Adkoonerstrator
I just ordered a 1.5 unit and a sensor. I'm going to need one before July or August. I wish the sensor wasn't so exspensive at $185. Oh well, it's only money right.
John
Old Jun 12, 2003 | 07:10 AM
nevrenuf's Avatar
I have an on-board wideband system.. with digital display and a RS-232 interface for logging to my laptop.
Here is the extra wideband O2 Sensor (black) mounted on my headers
And here is the controller mounted next to the PCM..
The wires go through the firewall. I have also direct connected the wideband controller to my PCM so I can get simultaneous air/fuel ratio, throttle position, and engine rpms via the same serial connnection to my laptop. This way I can log trims, etc. with Ease (via USB) and air/fuel, tps, and rpms via the Wideband controller, at the same time on my laptop.
Dump both data files into Excel and you've got a kick-butt tuning solution in my opinion.
Old Jun 12, 2003 | 01:27 PM
rodent's Avatar
I got the Tech Edge v1.5 unit. Works great and is EASY to install. The display is easy to mount and doesn't take up too much room. I velcro'd the display on top of my dash next to the pillar pod and it doesn't block road vision. Its able to log to a Palm or laptop.
Cost me $350 shipped plus $150 for the o2 sensor which I found at Autozone.
My post on it a while back
https://ls1tech.com/threads/showflat...;Number=514201
Finding an o2 sensor is a bitch though. V2.0 uses a widely available o2.
Old Jun 12, 2003 | 01:43 PM
XLR8NSS's Avatar
Adkoonerstrator
I followed one of the links at the Techedge site to SHO NUT Performance and they said they had the O2 sensors in stock. They were $185 dollars though. Autozone is out of stock.
Old Jun 12, 2003 | 02:22 PM
rodent's Avatar
Another kit:
http://www.plxdevices.com
$469 with sensor
Old Jun 12, 2003 | 03:05 PM
Mustang Hat'r 2's Avatar
I am going to try and wait until the 2.0 comes out. The 1.5 seems like to much of a PITA to get the sensor. Thanks for postint this for me 96SCTA
Old Jun 12, 2003 | 06:35 PM
Procharged LM7's Avatar
do any of these use the stock 02 location, Or do you have to cut a new hole to mount the new sensor? Thanks. Sam
Old Jun 12, 2003 | 06:39 PM
XLR8NSS's Avatar
Adkoonerstrator
The Techedge 1.5 unit outputs a narrowband signal so you can put the wideband sensor in place of your stock sensor, but I don't know if I'd trust that feature or not.
A new bung installed shouldn't be much at most exhaust shops.
John
Old Aug 26, 2003 | 09:57 AM
JeremyF's Avatar
LS1TECH Sponsor
I have 2 techedge units and they are great. However, I just ordered a different one that looks rather promising www.innovatemotosports.com I wanted this one since the datalogging capabilties look really nice. I will keep you updated on the quality of this unit.
Old Aug 26, 2003 | 03:36 PM
Technoman64's Avatar
Good link for the above link that does not work. This thing is awesome for $349.00
http://www.innovatemotorsports.com/lm1.php
Old Aug 26, 2003 | 08:49 PM
strokedls1's Avatar
I just got this unit and it works beautifully. Easy to use and works great. Just tuned a car last night with some freeway runs, and the stock senors are way off. .970mV O2 readings equated to 12.9 ish AFR. I would definately give it a thumbs up. We just put it in the rear driver side o2 bung since ATAP always shows his driver side as leaner. Car really woke up with the edit changes. I just record under wide open conditions.
