Over limit of grams/sec?
How are the guys with the turbos etc. getting these numbers with out running into these problems.
If thats not acceptable then you switch to an aftermarket pcm.
Gary
The stock computer can only handle numbers up to 512. 512 should be somewhere around 600flywheel horsepower. If your just a little past that I would just redo the PE table and keep an eye on things when it gets cold out. The PE tables don't compensate for weather changes so if you tune when it's hot and then it gets cold the motor will be leaner.
If you're talking about going WAY over that limit an aftermarket computer would be the way to go like stated earlier.
PSJ(site co-owner) is going to be testing out an aftermarket computer that might be alot easier on the wallet.
I believe Lingenfelter uses the stock computer with some "special" programming. Maybe you could call and see if they could help you out.
The numbers from the guy at whipple sound about right to me for a n/a motor, I know the equation to convert the numbers but, I'm not exactly sure of the conversion constant for a n/a motor. A blown motor would probably be around ~600 flywheel horsepower at that flow.
553g/sec = ALOT of power.
Hopefully in the near future we'll have a relatively inexspensive computer option but, until then you can either rig the stock computer to work or pay big bucks to go with something like a FAST unit.
