Dynojet owners/operators 224 248x inside please
Hey guys have a question or so for ya...
I tune on a local dynojet 224x. The dyno I use does not have the eddy current brake option, so i usually do VE tuning on the street (MOST of my tuning is actually done on the street) and just finish the cars up on the rollers. For NA cars and SC'd cars this works great. HOWEVER... I cannot tune WOT for turbo charged cars ont his dyno at all. As a matter of fact, it doesn't even load up the cars enough to get any type of realistic spooling. I will use my own car as an example... I have a 76mm (P76GTS) front mounted turbo and make 16-17psi on the street FAST in fourth gear (3K-3500 RPMs I'd say) but on this dyno, I cannot make more than about 10psi
Obviously I don't want to tune my car on it, but I can't even get numbers out of it. I hav seen an STS car that I didn't tune do the same on it.
Now... obviously the eddy current add-on would be nice, but that isn't going to happen at the place I use. Recently though, another local shop is looking at putting in a dyno and is talking with me about doing their GM work and asked me what I thought about the 248x. I have had my car on a 248 in the past and it had no trouble getting my car spooled and up into boost. I am still concerned about the accuracy of the loading though, which brings me to the central question of this post. For those of you tuning on 248s, when yout tune your WOT for TURBOCHARGED cars on the dyno, does the same final AFR carry over to the street?
Thanks for your time guys.
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
7 Second Club
The only turbo cars that I have had a problem loading properly on a dynojet without a brake control setup are the STS vehicles. All of the traditionally mounted front turbo setups do seem to spool slightly slower on the rollers but they still make the correct boost. For the turbo cars that duplicate the same boost level on the street as the dynojet it's pretty much identical a/f wise.
One trick I use for STS vehicles is to run it around 3500 rpm on the rollers for a minute or two cruising and slowly accelerating to get the turbo nice and hot and then do your standard pull. It's usually good for another psi or two on a non-loaded dynojet and get's you closer to a street/track pull.
Ed, thanks for taking a minute away from your busy day for me on the phone ![Angel](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_angel.gif)
Hey Nic, thanks for your input here... which one do you use, the 224 or 248? Like I mentioned above, I know that my car will spool just fine on a 248, is that the one that you use primarily? Or did you mean that most front mounted (like yours) will spool fine for you on a 224? As far as AFR is concerned, I guess what I was really asking is does the boost made there carry over to street loading pretty closely?
I have *never* tuned a turbocharged setup on a dyno, as I said, all I had available was the 224. I think those rollers sim a like a 2000lb load.
The only turbo cars that I have had a problem loading properly on a dynojet without a brake control setup are the STS vehicles. All of the traditionally mounted front turbo setups do seem to spool slightly slower on the rollers but they still make the correct boost. For the turbo cars that duplicate the same boost level on the street as the dynojet it's pretty much identical a/f wise......
Has either shop considered a 224xlc? Thats what I have and love it. Some cars will not have an issue with loading however some (like STS I have found also) will. For this the loading dyno is really handy. It is also nice to slow down some of the big power cars so you can really see what is happening.
Also, another interesting note. I have not seen a GM yet change AFR between a loaded pull and a unloaded pull. I have notice that Ford cars do change AFR quite a bit when loaded. Its never predictable. Some go rich while others go lean.
Tuning on a 224 unloaded and going to the street for non-turbo cars seems fine, and I always check things. IF there is ever a difference, it's only a tenth of a point or two in AFR. And as is always noted, more timing can be run on the 224 unloaded than the street.
Thanks for the info guys.
I dont know much details about it, but I work for a tuner/ dyno shop. Our dyno is the 248 and I am pretty sure he just uses the brake to load up the turbo cars, and he has done quite a few so I am pretty sure that works well.
7 Second Club
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
No dyno will be a perfect example of what will happen on the street/track but you should be able to get damn close.
LS1TECH Sponsor
If you'll allow me to add...
Turbos rely on load to spool up. They spool up on heat energy, and that is directly proportional to the load that you put on vehicle. If the rollers weigh x and the car y, you will have different loading and while you can get the tune very close as is mentioned above, the question (and worry for the shop owner and tuner) is whether the car will be fully tuned for what it sees in the streets. We use a Mustang dyno and can load cars up far past what they can achieve in the streets, thus allowing us to tune the complete range. We have yet to see a car come back with any problems. If you can't fully load the car, you can get close to an ideal tune at the loads that you hit while on the dyno, but do you really want to risk guessing with the tune beyond those loads? And the street is no place to load a car in 4th gear at 16 psi (sorry for the nanny remark)! I certainly don't want to pay warranty money out for stuff like this, so instead we just bought a better dyno to begin with. What I'm saying is that if the shop you deal with can't pony up for a load cell dyno, at least make sure that they can upgrade later. If anyone is serious about tuning performance and making sure the customer cars stay safe, durable and reliable, you simply have no choice. You must buy adequate equipment. I'm not trying to burst any bubbles here or step on any toes, just point out a simple and long standing reality.
Yes. When I tune a BS3 equipped car in open loop, then turn on the wideband at the track I usually have 0-2% correction, the air/fuel being nearly identical to what it was on the dyno.
