Need Quick Hypertech Answer!!!!!
Old Nov 30, 2007 | 12:00 PM
TRANSAM75's Avatar
Default Need Quick Hypertech Answer!!!!!
I have a chance to purchase a used programer for my S10 for $75. The owner says the stock tune was returned to the truck it was bought for, Can i now use it for my truck? Or will it still be "VIN locked"? I am going to plug it into my truck when i go to purchase it to make sure it works. But if someone can answer my questions by 3:15 today that would really help!!
Old Nov 30, 2007 | 12:22 PM
kerryt1's Avatar
if the other truck has been returned to stock, it will work fine. just make sure and test it out before you use it if possible. If not, then you just have to take the guy's word. You can send it in to Hypertech to be unlocked, also.
Old Dec 3, 2007 | 09:15 AM
TRANSAM75's Avatar
I got it, and loaded in the firmer and higher shifts. Worked great except now i have a random miss at idle, and i DID NOT load in the engine tune. When i put it back to stock, no miss. Any ideas?
Old Dec 3, 2007 | 11:47 AM
kerryt1's Avatar
you don't have a choice in loading the new "engine tune." It does it automatically if you're messing with shift points, etc. You get either:
A. 100% stock
B. Hypertech ignition / fuel map + whatever else you change
That's why they're inferior, IMHO, but it was the cheapest way for me to correct my speedometer for the oversized tires.
Old Dec 3, 2007 | 11:49 AM
TRANSAM75's Avatar
No, on my truck, it is optional. It asks if you want the engine tune or stay stock.
Old Dec 3, 2007 | 12:12 PM
kerryt1's Avatar
Right...but if you pick stock, do you then get the option to modify the transmission parameters, etc?
Old Dec 4, 2007 | 08:36 AM
TRANSAM75's Avatar
Yes!!!!
Old Dec 4, 2007 | 11:09 AM
kerryt1's Avatar
Gotcha. Well, that was not possible with the programmer I had. I think your best bet is to call the good folks at Hypertech and ask questions. Most people on this site stay away from handheld programmers.
Old Dec 4, 2007 | 12:35 PM
TRANSAM75's Avatar
$75 is easy to swallow!!!
