Misfires & TC unlocking
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Ever since the cam and heads install. I still get alot of misfires at part-throttle causing my TC to unlock on the freeway. Any ideas?
I also have EDIT and have modified the idle and low rpm table to 32000. That help with the code.
But still have enough misfires to unlock the TC.
I and some of others have similar issue...it is in the mid rpm.
this is what I did in the 2 med rpm tables: instead of using 32000 for the entire tables, find the low spots and increase them to a few 1000s.
But not sure which cells to modify.
In my case, I'm lazy to try...so I just put 'em @ 5000 and it has been working fine.
Good luck,
Gotcha, will try that. And let you know. Thanks.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
