Big Stuff 3 help
Old Mar 2, 2008 | 05:12 PM
Big Bird WS6's Avatar
Default Big Stuff 3 help
when using the bs3 what can i all get rid of under the hood?
can i delete all motor wires?
and what do i need to make my dash still work?
Old Mar 2, 2008 | 05:27 PM
Frost's Avatar
Nothing, if you want your dash working you will be adding wiring in fact. You will have to keep the factory PCM installed and talking to things so that it thinks it's still running the show to some extent, and it will run your dash for you.
Old Mar 2, 2008 | 05:31 PM
Jake@EPP's Avatar
Speed INC sells a harness delete kit for the 99-02. Depending on what trans you are running you can either run the factory PCM for trans control or the BS3 if you purchase GM Trans.
All in all, its a easy swap, the bs3 for boost is light years ahead of the stock computer. Since you are looking into the twin fuel systems this would be a more precise way to go about doing it.
Let me know if you need anything, we are a Bigstuff tuner and dealer as well.
Old Mar 2, 2008 | 05:34 PM
Frost's Avatar
How much [roughly] does that harness cost Jake? Just browsed their site real quickly but I didn't see it.
Old Mar 2, 2008 | 05:39 PM
it is like 500 i saw it too. but i heard they are really pricy on the bs3. what is the best place to get the bs3 program?
Old Mar 2, 2008 | 05:41 PM
jake.
pm me your best price on the bs3
thanks
Old Mar 2, 2008 | 05:43 PM
Jake@EPP's Avatar
We sell the entire system and any sensor needed.
If you need to spare a few bucks for the setup, i can set you up with the necessary wiring to run the stock computer to run the factory gauges. I believe the modifications are under $100 and this is for a auto car.
Old Mar 2, 2008 | 05:45 PM
Jake@EPP's Avatar
jake.
thanks
I do not have the 08 pricing sheet with me at the moment, give me a ring this week, id like to go over your combo/needs to figure the best setup for what your trying to do.
Old Mar 2, 2008 | 05:50 PM
Jimmy P's Avatar
The Speed Inc harness is $550.
