Threw a code.
Old Mar 7, 2008 | 01:44 PM
slaptastic's Avatar
Default Threw a code.
P0106....Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
How do I fix this? I cleared the code once already and it came back. I just put in a cam so maybe that's why? I'm also pulling one of the heads because I broke a header bolt inside. Should I look for anything while I'm doing this? Should I replace the MAP Sensor?
Cam is a TSP 233/239. Also put in a new timing chain, oil pump, valve spring set, and push rods.
Old Mar 7, 2008 | 02:09 PM
crazy Jim's Avatar
vaccume leak?
also check this thread p0106
Old Mar 7, 2008 | 03:36 PM
King Nothing's Avatar
have you gotten a tune yet?
Old Mar 7, 2008 | 09:43 PM
slaptastic's Avatar
Not yet.
Old Mar 8, 2008 | 02:29 AM
35th SS's Avatar
its either a vac. leak or your idle is low.raise your idle to about 850-900rpm.
Old Mar 8, 2008 | 11:00 AM
2xLS1's Avatar
Any cam bigger than about a 224 needs the min and max values for the P0106 diagnostic raised in the calibration.
Old Mar 9, 2008 | 12:05 PM
slaptastic's Avatar
So it's really no big deal. I just need to get my car tuned?
Old Mar 9, 2008 | 04:15 PM
Bill Bowling's Avatar
I had the same problem after cam. Needs changes in tune to correct.
Bill
