dyno depression....look.
Well Chuck at HPE could not tap into my PCM(PCM wouldn't allow it) and would not even recognize the VIN for the PCM to flush and fill it and start fresh.(???)
The Dyno was reading 13 for the A:F and 23* timing, was running rich up top and the rev limiter was set at like 6150 rpm...*shrug*
The Car made 373 rwhp and 368 rwtq....WTF dude..thats with a M6 and 3.42s, cam, exhaust, FAST 90/ NW 90
Here are my mods:
Futral F14 cam 232"/234" .598 "/.598" 112LSA
Patriot dual Gold Extreme valve springs
Comp cams Chrome Moly Pushrods 7.400 (Stock Length)
Futral motorsports ported LS6 oil pump
LS2 timing Chain
90mm FAST intake manifold
90mm Nick Williams Throttle Body
30lb SVO injectors
Mac Mid Length Headers
Off road ypipe
QTP electric cutout
Magnaflow muffler welded in stock cat-back
MTI lid w/K&N
Heres the graph:
What the hell is going on with my car..
I have the realtime option for HP Tuners and have no issues datalogging this operating system with EFILive, I just can't flash it.
The guys who did this really fucked the tune up, car drives fine, but come on! LS6 cams make more power than that!
big plumbing car. That says air is choked. Start with
some basics like being sure the throttle is dead open
with the pedal matted (some big TBs won't fully pull
without changes to the cable and possibly deletion of
the TCS/ASR contraption). 23 degrees seems like a
little short timing but not super terrible, 30 is usually
ping limit on a stockish motor and a built one needs
less.
