Houston We Have A Problem Please Help
Old Jun 14, 2008 | 10:00 AM
Travose21's Avatar
Default Houston We Have A Problem Please Help
Ok This Is The Last Thing That Is Wrong With The Car. I Changes Every Sensor In The Car. Including Plugs And Wires. When I Drive My Car It Hesitates And Sputters While Drive And When I Give It Some Gas It Tries To Clear Out And Then It Does And Then It Turns On And There It Is Full Power Again. I Changed The 02 Sensors Again Thinking I Have Some Defaulted Ones And New 02 Extensions What Else Can Be My Problem
Old Jun 14, 2008 | 10:31 AM
Travose21's Avatar
Btw No Ses Codes
Old Jun 14, 2008 | 10:33 AM
00'WS6Rocket's Avatar
I had the same problem a few months a go and i cleaned the maf, iac and throttle body real good, also check that your battery connections are nice and tight.
Old Jun 14, 2008 | 11:00 AM
Travose21's Avatar
Ok And What Fixed Your Problem
Old Jun 14, 2008 | 11:09 AM
Well I after I cleaned the iac,maf and tb before I started the car I noticed that the live wire on the battery was very loose, so really it could have been any of that. It only took maybe 1 1/2 hour to take everything off and clean it and let it dry and then put it all back on. But easiest first id check the battery cable if tight maybe clean the parts, once you take them off, if they've never been cleaned, they are very dirty at least mine were.... But I was having the same exact problem that sounds like you are having. my rpm would also jump to 3500 for an instant at idle, that why I thought it was the iac. hopefully this fixes your problem as it did with mine.
Old Jun 14, 2008 | 11:27 AM
Travose21's Avatar
Where Is The Iac Located
Old Jun 14, 2008 | 11:29 AM
its bolted on the side of the tb you you pull it out it should look like a black mushroom shape i think theres two things bolted on tb i'm pretty sure its the top one
Old Jun 14, 2008 | 11:31 AM
there will probably be black junk on the iac and in the hole on the throttle body, thats why I just took the tb off and cleaned it with tb cleaner, there was alot of that black junk around the butterfly on both sides
Old Jun 14, 2008 | 01:14 PM
Travose21's Avatar
Default anyone
anyone else have any imput what could it be
Old Jun 14, 2008 | 03:41 PM
ZL1Killa's Avatar
GROUND WIRES. LOL. check all locations for ground wires
Old Jun 14, 2008 | 04:26 PM
Travose21's Avatar
what ones to check i know there are plenty of them i just want to find out which ones you can narrow me down too
Old Jun 14, 2008 | 05:25 PM
Travose21's Avatar
ok bank one is reading 1.59 and bank 2 is reading .049
Old Jun 14, 2008 | 05:49 PM
OUTLAWZ RACING's Avatar
Check the back of the intake and make sure the little vac line is plug up. A quick check is turn on your AC and make sure it blows in the vents. Also check your fuel injectors make sure the wire are tight. Then check the fuel pressure and coil packs. Sounds like your geting un meterd air some where also. Are you sure you dont have a bad valve spiring or bent push rod? Oh and that little evap thing on the other side of the intake make sure its plug in and not crack.
Old Jun 15, 2008 | 09:06 AM
Travose21's Avatar
ok ill try that
Old Jun 15, 2008 | 09:35 AM
edcmat-l1's Avatar
Are you sure you're reading bank one right? Sounds like bank 2 is dead, which would force entirely too much fuel, causing the bank one to go through the roof.
And it would cause the symptoms you describe.
I know you said you replaced the 02s and extensions, but you could have a burned wire or something.
What are you using to scan? you may want to unplug the 02s and see if they dont go to 440mv or so. If one doesnt, you've got a wire shorted to ground.
