Best Wideband?
I have used the LC-1 and still have one along with the XD-1 serial gauge and I must say that it is the biggest piece of crap I think I've ever owned as far as widebands are concerned. Not only did the analog outputs burn out but it is near imposible to get a clean reading from the noisy LC-1 design.
And last but not least another crappy wideband I used was the AEM UEGO gauge style wideband. I tried 2 different ones and both gave the same bad results. They worked normally but the readings on 2 different units were off. I could tune my personal car with it and the next day come out and take a drive and the afr's would be completely off and not to mension the crazy slow display response. I compared the last one I had to my LM-1 with the sensors within 3 inches of one another and the AEM couldnt keep up and was in some places as far as 1.5 points off. So I sold it the next week!!! Oh and tuning my personal and customer's car's with the LM-1 gave me back to back good results. I get the AFR set and the next day it is still the same!!!
Also If Im having a missfire I know it immediatly, because one bank goes dead lean, and I also know which bank to start looking right away.
You can do it either way. Individually which takes both analog outputs being plugged into the dyno or if you average it only outputs the average to one wire. I personally always record individually and if I want the average I set up a channel on the dyno that averages them for me automatically.
(click to enlarge)
They actually make a stand alone sensor w/o the display screen specifically for dynos. Our shop now runs one of these in each header primary to see indiviual cylinder A/F ratios. Now it looks like this.
Here is a link http://www.fuelairspark.com/Products...r/02sensor.asp
