Have LC-1 Experience? IN HERE!!!!
Old Sep 25, 2008 | 09:26 AM
stevegrizzle's Avatar
Default Have LC-1 Experience? IN HERE!!!!
Ok, so I had my lc-1 set up to have the yellow wire outputting to efilive and the brown wire was running to nothing.
I just got a dynotune wideband gauge and my lc1 appears to be outputting in lambda rather than afr. So I open up the LM programmer on my laptop and I can't seem to program it. When I click program nothing happens and when I reopen the lm programmer the settings havent changed......
**Update, ok I found all the info and changed the settings to 1.0 for 10 and 2.0 for 20 and I set it to use afr's. It keeps the voltage settings but goes back to lambda every time. WTF?!?!?!
Old Sep 25, 2008 | 09:34 AM
Rob@EFIAlchemy's Avatar
LS1Tech Sponsor
do you have the black wired grounded to reprogram the lc1 unit itself
Old Sep 25, 2008 | 09:52 AM
no i have the button wired- in.
Old Sep 25, 2008 | 09:54 AM
Old Sep 25, 2008 | 10:21 AM
LS1Tech Sponsor
on lambda just set it to .883 and 4.215
Old Sep 25, 2008 | 10:30 AM
I dont understand how this will help anyways as i need it to output to my afr gauge.....and I need it in afr not lambda.
not trying to come off as a *****, youre confusing me. please make a little more of an explanation
Ok so I tried that and it seems to have accepted teh setting but it has not changed the display from reading 00.7 to 1.2
Old Sep 25, 2008 | 10:44 AM
LS1Tech Sponsor
we normally calibrate them using efilive but using the lm programmer after you change the setting to afr then go into advanced settings and change the gauge read speed to 1/3 second and see if that will program it for you
Old Sep 25, 2008 | 10:48 AM
it keeps going back to lambda.........wtf this makes no sense.
Old Sep 25, 2008 | 11:11 AM
LS1Tech Sponsor
is the gauge not reading it
Old Sep 25, 2008 | 01:26 PM
Doc's Avatar
Doc
Did you remove power to the LC-1 after every software change with LM programmer? Simply closing out LM programmer will not make the change permanant- you need to power down the LC-1 and "reboot it."
Old Sep 25, 2008 | 03:23 PM
so how long do i need to keep the ign off for ? couple seconds?
Old Sep 25, 2008 | 11:40 PM
Doc's Avatar
Doc
Yeah, a couple of seconds is fine.
