When I put headlight down, it makes a lot of noise
When I put head lights down it makes a lot on noise. Sounds like gears grinding on the driver side when light reaches the closed position. It last for about 20 seconds. It does closed all the way. I think that the motor is going bad, but would like to make sure before I buy a new one. This is on a 99 Firebird.
Thanks for any help. Darren
DO NOT BUY A NEW MOTOR! mine does the same thing, but I haven't gptten around to fixing it.It happens to all headlight motors. You can buy a replacement for the stripped headlight gear VERY CHEAP! The stock ones are made of plastic, someone has made an exact copy out of brass that will last forever. you can get the whole story and buy them here
http://www.bfranker.badz28.com/headlightfix/index.htm
Good luck!
Good luck!
Actually it is the motor on the headlights, mine was doing the same thing and I took it to the dealership and got it serviced. I think it costed around $300.00.
The headlight system on our cars measures amperage to know when the light is fully up and fully down . When the plastic gear inside the motor is stripped power is still fed to the headlight motors because it hasn't detected the high amount of amperage to know to stop powering the motor ...Do the temp fix and eventually get the brass gears!!!
Thanks alot everyone for the info. Transamula thanks for the web page .
Looks like I will be buying a gear from http://www.bfranker.badz28.com/headlightfix/index.htm
Again, to echo the sentiments here, buy the brass gear.
My drivers light did this, I did the 180 flip and got about another month out of it. Swapped the gear and it worked like a champ.. Then about 2 months later the other side puked and I swapped the gear out in it (buy two of them because the other WILL fail eventually).
Took about half hour a light but I was slow and methodical so I could put it back together since I don't work on cars often enough to do it from recall.
HTH
HTH
My passenger side Light wont come up anymore. What could it be?? Its not even making a sound like it completely stopped working. I don't think its the gear beacse like you all said that grinds when it goes but this isnt even making a sound. I checked the fuse and its fine. please help me cause its bothering me and i cant afford a new motor.
