Firebird Headlights--ALL COMMENTS/QUESTIONS REGARDING HEADLIGHTS GO IN HERE
Old 04-18-2010, 01:50 AM
  #781
Fosnot's Avatar
Originally Posted by offroadfury6
whats a bezel? the black retainer arund the lights?
Exactly.
Old 04-18-2010, 01:43 PM
  #782
offroadfury6's Avatar
dang, im trying to install some of brents gears but one of my headlights will not come up at all...manual raise doesn't even work. what should I do? force it?
Old 04-18-2010, 04:16 PM
  #783
bump...anyone know how to raise the headlight if the auto switch doesn't and manual raise does nothing? ALOT of grinding going on, I dunno how to get the fixture out while it is closed...
-trying to install brents gears. thanks.
Old 04-18-2010, 05:28 PM
  #784
Danny2tek's Avatar
maybe have somebody do the switch and you GENTLY try and help it up?
Old 04-18-2010, 06:25 PM
  #785
all is fair to try at this point...my other motor is sitting, the eproxy is "curing"...I bet those tabs on the motor are wayyyyy loose and probably not even close to the worm drive hitting the teeth
Old 04-19-2010, 06:06 PM
  #786
ok, I found the problem...when I did the "free fix". I installed the bolts backwards so the thread was sticking out almost as far as the stopper. so the problem was the arm got wedged between the stopper and the thread off the bolt...I've got the fixture out and am currently working getting the motor off so I can install brents 2nd gear
thanks guys....beware which way you guys re-install your bolts!!!
LIVE AND LEARN!
Old 04-19-2010, 08:47 PM
  #787
Danny2tek's Avatar
that got me my first time but I caught in time.
Old 04-19-2010, 10:18 PM
  #788
^^^ haha it happens. I got the right side back in, the drivers motor is "curing" as we speak
Old 04-22-2010, 08:43 PM
  #789
tmc2k1's Avatar
Can anyone tell me if its possible to get white white headlights without going HID's? I have LED bulbs in the DRL's and recently put HID's in the fog's and it looks great! Only now my headlamps look horrible in comparison.
Am I stuck with having to buy HID's for the headlamps to get a white look? Will those Sylvania XtraVision beams be any whiter?
  #790
tmc2k1's Avatar
Old 04-22-2010, 08:49 PM
  #791
Danny2tek's Avatar
If your using the stock bulb 4701/4703, then no.
Old 04-22-2010, 08:50 PM
  #792
tmc2k1's Avatar
What about if I use the LMC housings?
Old 04-22-2010, 08:56 PM
  #793
Danny2tek's Avatar
I ran the Sylvania's I forgot which model though, I know it wasn't the ones that are like $40 those are way to yellowish.
Just pull the trigger on the HIDs, for the price on those Sylvania just spend an extra twenty bucks and you have HIDs that will match everything else..... you know you want to
Old 04-22-2010, 09:06 PM
  #794
tmc2k1's Avatar
I'm just a little weary about putting HID's in any other other than a projector. I really don't want to blind people or **** them off. If these LMC housings will NOT **** off other drivers with HID's then I am all for it.
If I got the LMC bulbs for the low beams which bulb is that? 9005 or 9006? Do I need that Heavy-Duty Harness if I run a higher watt bulb in there or if I use HID's?
Old 04-22-2010, 09:52 PM
  #795
Danny2tek's Avatar
I installed mine yesterday I literally stood in front of the car at different distances and angles and I was not blinded by them. Its 9006 for the lows.
If your using the 55 watts then maybe you should use relay-harness
Old 04-22-2010, 09:55 PM
  #796
tmc2k1's Avatar
If I do HID's I will use the 35 watts for sure. I am sure that 55 Watts in something thats not a projector will cause WAY too much glare.
I will most likely do HID's. I know they will look good and light up the road. My ONLY Concern with them is blinding other people. Some people might not care, but I don't want to **** other people off no matter how badass they might look. I am glad that it looks like the LMC housings will fix this.
If I use the 35 Watt HID's I will be fine and not need the relay harness correct? Also, I won't need that heavy duty harness shown on the LMC site correct?
So all I need to order is the low beam LMC housings (Will get high beams at a later date) and a 35W HID 9006 kit from DDM and everything will install just fine? Nothing else needed? Any splicing or cutting wires involved? Thanks SO much for your help!
Old 04-23-2010, 07:53 AM
  #797
Danny2tek's Avatar
If you don't want to cut and splice, all the harness/adapters are included with both kits.
Old 04-23-2010, 11:48 AM
  #798
tmc2k1's Avatar
Thanks Danny. My final question is about the Heavy duty harness listed on the LMC order page. Is that necessary if I get the 35W HID kit? Or only the 55W?
Thanks again for your help. Your setup looks GREAT BTW (In the electronics section)
Old 04-23-2010, 05:35 PM
  #799
Danny2tek's Avatar
not needed
Old 04-23-2010, 06:11 PM
  #800
tmc2k1's Avatar
Do you have any pics of your setup from the front? It looks great from the in car view, but I would love to see it from the outside.
Thanks!
Quick Reply: Firebird Headlights--ALL COMMENTS/QUESTIONS REGARDING HEADLIGHTS GO IN HERE
