Firebird Headlights--ALL COMMENTS/QUESTIONS REGARDING HEADLIGHTS GO IN HERE
Old 07-05-2011 | 12:26 AM
  #1101
JasonWW's Avatar
Originally Posted by the_dragon
My driver side low beam headlight is having major issues.
The motor for the headlight been replaced before I bought the car back a few years ago.
The headlight was replaced about two-one year ago.
This spring it started with something odd.
The pigtail started to burn so i replaced the pigtail and cleaned off the headlight.
Well the second pigtail is now deformed and burnt too.
So I just unplugged it because the smoke was becoming to much from the burning pigtail and it doesn't seem safe unless my name is Billy Bob Joe who married his first cousin.
So my question regards of what to do?
Do you mean the pigtail on the back of the headlight?
Where did you get a replacement from?
I remember I had a metal pin in the plastic plug that had several broken strands of wire and it caused it to overheat. The simplest fix is to ditch the plug and crimp on new insulated connectors and label them H and L and of course the black wire is the ground. Make sure the plugs slide on tightly. that will solve that problem.
Old 07-09-2011 | 09:57 PM
  #1102
the_dragon's Avatar
It was a eBay one that looked great in quality but wire was not as heavy duty
Old 07-10-2011 | 12:02 AM
  #1103
ISMELLRICE's Avatar
drivers side head light didnt wanna pop up after multiple attempts...finally after about 10x's it finally popped up..kinda weird
Old 07-13-2011 | 10:21 PM
  #1104
ws6transam98's Avatar
Does anyone know where I can find a kit to where my headlights don't flip up they are just half open all the time?
Old 07-13-2011 | 10:25 PM
  #1105
Danny2tek's Avatar
Search "Breathless conversion"
Old 07-13-2011 | 11:01 PM
  #1106
JasonWW's Avatar
He's not talking about the Breathless piece.
The half open thing will have to be made yourself. You'll need to swap to a short, wide lens like the lt1 camaro's had.
Old 07-14-2011 | 07:52 PM
  #1107
Is that the only way to do it? And I don't really know how I would do that..can you explain a little? Sorry I just don't want to mess anything up
Old 07-14-2011 | 09:15 PM
  #1108
JasonWW's Avatar
Where did you see a crazy half open headlight in the first place?
I've only seen them on Silvia's/S13 and S14's. Mostly in Japan. Afaik, they rig them up themselves.
Old 07-15-2011 | 02:12 PM
  #1109
xenomorpheus's Avatar
Ive had it with these gear motors and linkage.. Even if I get everything tightened up, one side seems to jiggle a little when driving, I've put in the brass gears but the sides keep moving even with band clamps.. F that crap
I've decided to go for gold and plan out a solution using 12v linear actuators with built in limit switches. The throw shouldn't be much if I'm going to put in projectors and the mounting angle should keep the assembly from bouncing around at speed or bending if someone leans on it as it will be triangulated. Another side benefit is the ability to have it open and close at a slower speed instead of slamming down and getting looks from people thinking you just hit a car.
The only thing I have yet to figure out is how to integrate with or hack the stock headlight controller(if it is even possible). When the actuator hits the limit switch, it shuts off so the headlight controller won't see the added draw to determine if the unit has stopped (I guess that's how it works). Maybe I can integrate some kind of timer into the circuit.
I found several online for about 75 each because you should only need like 15lb max and a 6" or 8" stroke pulling 2A when loaded. Maybe one without limit switches would put a high load when they hit the ends and could work with the stock controller, but I have no idea yet, just vomiting my thoughts out here to see if anyone has done or thought of similar..
I tried to read this thread, but 111 pages is a bit much. Apologies if this was covered but I only saw threads about hoods or hatches with actuators.
Old 07-15-2011 | 04:58 PM
  #1110
I seen one while I was driving and it looked awesome! And man you just blew my mind lol. Have you attempted to do any of it yet? I was going to buy a spare headlights and gears an just try it out and brain storm with them and see how it works out. I haven't tried anything with them yet but I would like to get something done with this. It's starting to really irritate me
Old 07-20-2011 | 01:10 PM
  #1111
AwsmGy's Avatar
Just posting a follow up from the previous page. It turned out that for whatever reason my HID's were making things angry. If I turn off my floods before locking/unlocking my car I have no issue.
Old 07-20-2011 | 07:36 PM
  #1112
JasonWW's Avatar
Are your hids powered straight from the battery using a relay?
Old 07-21-2011 | 10:47 PM
  #1113
lsgriff's Avatar
i just replaced my pass side headlight motor and now my headlights are out of sync. i've tried several things and no luck... anybody had this problem? i'm currently sifting through the 60 pages but no luck...
Old 07-22-2011 | 12:12 AM
  #1114
donati98ta's Avatar
anyone know if there is a way to cut off the lights from opening and closing while unlocking. im cool with the fogs flashing but dont like the headlights going up and down ... let me know
Old 07-22-2011 | 03:10 AM
  #1115
JasonWW's Avatar
Get one down, pull it's fuse then get the other down, put fuse back in.
Old 07-22-2011 | 03:16 AM
  #1116
JasonWW's Avatar
Do you have a motor that's messing up?
If so, the temp fix to keep the lights from activating from the key fob is to pull the fuses.
At night I would put the fuses in, raise both lights, then pull the fuses back out. Then in the day, put the fuses in, lower the lights, and pull the fuses back out. It's inconvenient, but will work till you get the motors fixed.
Old 07-22-2011 | 07:01 PM
  #1117
lsgriff's Avatar
I'm pretty sure I tried that but I will try again.
Old 07-22-2011 | 08:53 PM
  #1118
AwsmGy's Avatar
No, they're just powered by the stock harnesses.
Old 07-22-2011 | 09:10 PM
  #1119
JasonWW's Avatar
Their supposed to go through a relay. The stock headlight switch isn't designed to handle the much higher load that the ballasts create during their warm up cycle. Switches have been known to burn out and wires smoke. Not a good thing.
Plus no wonking side effects.
Old 07-22-2011 | 10:02 PM
  #1120
lsgriff's Avatar
Didn't work. I have no idea what else to do. I'm starting to think the motor was assembled or wired wrong
Quick Reply: Firebird Headlights--ALL COMMENTS/QUESTIONS REGARDING HEADLIGHTS GO IN HERE
