Lights for aftermarket gauges
For those running aftermarket gauges, what circuit are u tieing into, and where? Noob question but I can't find an answer that I feel comfortable with. 02 TA. For switched power are u guys just tieing into the open IGN spot on the fuse box beside the steering wheel control fuse?
Get a spade connector and crimp it onto the end of the 12v+ wire for the gauge and slide it into one of the spots labeled "accessories"
Test it out by turning the key on..
Does the accessory slot work for the lights, or does it come on with the ignition? I have my switched power going into the open IGN slot. I'd test it but my car is in pieces right now so turning it on to test isn't an option, or I would have tried it. Thanks guys.
