Cracked interior door panel...:( *DON'T QUOTE PICS!
#361
1 Post
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Its been over 2 1/2 years since my fix and its holding up great!
check out post 159 for my writeup with pics.
https://ls1tech.com/forums/showpost....&postcount=159
#362
1 Post
From my understanding in the HPP magazine. With the staples the way they are installed from the factory; it's putting alot of stress there on that portion of the panel. I believe if you take the staples out and relieve the stress, let it relax, and put staples in it relaxed. It shoud keep the cracks from comming back or appearing on cars that don't have the crack. That's how I read it in the HPP mag.
#363
Saving this its good info. Im going to do this 2nite.
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
#364
I am in the process of replacing the panels with pre 99 plastics with my 99 carpet inserts. And although the color is not a perfect match, it is very close. And the pre 99 plastic is far superior by the way.
just though this is a better solution than patching a broken part.
And I have one done already and installed, the other is still in the works.
#365
#366
Used the machine screws to replace the staples as in High Performance Pontiacs fix. Removed ALL staples. Replaced all with machine screws, then used kitty hair on the back of the panels for extra support. So far, so good.
#367
My passenger side is cracked all the way down and my drivers is just beginning to show. Tomorrow I'm taking the panels off and removing the staples. They'll probably have to stay apart for a little while, until I can get some repair supplies. Chock another guy up who's dissappointed in GM for not stepping up to this issue. I know they have bigger problems at the moment, but if they hadn't given CEO's and other bigwigs millions of dollars to mismanage this company, they could afford to admit they produced an inferior product and make things right with the people who are supporting their company.
#368
There is a whole bunch of plastic spikes similiar to the end of a golf tee. Then once it's thru.......GM melts the end into a circle like a flat washer. And that's basically how the insert and lower tray is held on.
I guess you can grind or drill the plastic **** off to free everything. But once you do that, I don't really see how you can reattach it back as there will be nothing left. Maybe you can try using small self tapping screws and washers from the back side.
#370
I just completed reinstalling my Drivers Door Panel. After being twisted for ten years the panel didn't want to go back to its intended position very well. I added a little epoxy to the back side and that helped to reshape it. I'm dissapointed in the Vinyl Repair Kit though. I followed the instructions to the letter, had my color matched perfectly, applied it to the damaged area, then heated it with the grain sheet on top to set it, and the compound would not set. No matter what I tried. More heat, less heat, more time less time, 10-15 times. I always ended up with sticky left over color, that I finally just wiped away and called good. I can still see the crack, but its alot less noticeable, and the panel is way straighter. In all, I'm satisfied. Especially knowing the panel shouldn't get any worse. Thank you BANDITCAR. And thank you High Performance Pontiac. Now onto the Passenger side...
#371
Passenger Panel is back in the car. I had a little better luck with the Vinly Repair Kit this time. Far from perfect, but I'd say it looks descent until I can find some replacement panels for a reasonable price. It kinda resembles a scar from a really deep cut, which is fitting. Definitely an exercise in patience.
#372
![Cool](https://ls1tech.com/forums/images/icons/icon6.gif)
True. I've been careful about that too. It might bump it, but if it does I always put it back up to not allow it to be stressed.
I've used Maguires vynil protectant on it too - might that have something to do with it? I know I've heard that Armor All will actually kill what it's supposed to protect, but I thought Maguires to be in a whole 'nother league.
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
thanks
1 Dumass
#373
I do interior repair for a living, and I have seen that problem on almost every trans am I have been in. I do not recommend fixing it until you are about to sell it. It will either break back open, or cause stress somewhere else causing that spot to crack. If you can live with the site of it, don't fix it until you are ready to get rid of it. Both of my doorpanels are cracked like that right now and I am not even going to touch them lol.
#376
I have an 02 trans-am not ws6 package and has 60K, My driver side door panel is cracked, noticed it right after I bought it, btw not a tech but was wondering if anyone knows what the stock horse power and torqe is at the engine and rear wheels, it is an automatic trans, but now I have installed Magnaflow exhaust, power-plus BBK throttle body, K&N FIPK generation II , 3.73 Richmond built gears, super chips programmer, so can anyone tell me the horses and torqe now ?? and if the stock transmission is a performance transmision ??
thanks
1 Dumass
thanks
1 Dumass
Get it dyno'd.. you can't estimate what it is going to be with different stuff on it. And I don't know much about the 4L60E Transmissions, but I haven't heard any problems from anyone.
